Blynk disconnects every 6 hours roughly
#1
Looking for some help with my project. Mcu is a arduino mega with a 5100 ethernet sheild.
Its happened a couple times now, blynk would disconnect for no reason and will not reconnect unless i press the reset button on the ethernet sheild.
If also noticed it has discomnected before when i have triggered a relay from the app using a button. Strangly it dosnt do this when my phone is on the same network. Only when im away from home and dosnt do it every time.
Im not in front of the pc right now to share my code but will post it up in a few hours. Remains sowhat the same from my last post on here where i shared my code.
Any help/ advise would be greatly appreciated
Cheers Adam
#2
You will need to look at using connection management routines to monitor Blynk connection status, and if unavailable reboot the Arduino.
This is a basic example you will have to tailor to the Mega and Ethernet…
#3
Sweet, having now read through that, it would appear i need to have a big sort out with my code. A lot of things like blynk widgets are currently above the setup()
#define BLYNK_PRINT Serial // Enables Serial Monitor
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h> // This part is for Ethernet stuff
#define W5100_CS  10
#define SDCARD_CS 4
#include <TimeLib.h>
#include <WidgetRTC.h>
#define BLYNK_NO_BUILTIN  // Disable Apps built-in analog & digital pin operations
char auth[] = "37fa064f76dd4cd78653d7330df74232"; // Put your Auth Token here.
WidgetRTC rtc;
WidgetTerminal terminal(V59);
//Temperature
#include <OneWire.h> // Get 1-wire Library here: http://www.pjrc.com/teensy/td_libs_OneWire.html
//Get DallasTemperature Library here:  http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
/*-----( Declare Constants and Pin Numbers )-----*/
#define ONE_WIRE_BUS 48// DS18B20 on arduino pin
DeviceAddress Probe01 = {0x28, 0x47, 0x27, 0x7C, 0x32, 0x14, 0x01, 0xE5};
DeviceAddress Probe02 = {0x28, 0x39, 0x3C, 0x72, 0x32, 0x14, 0x01, 0x77};
float tanktemp;
float sumptemp;
float tempaver;
BLYNK_CONNECTED() {
 rtc.begin();
 // Request Blynk server to re-send latest values for all pins
Blynk.syncAll();
//ATO switches and relay
byte lowWaterPin = 6;    // Goes LOW when water below switch
byte highWaterPin = 7;   // Goes LOW when water below switch
byte pumpPin = 8;        // Relay to control the water pump
unsigned long maxRunTime = 60 * 3000L;   // pump on for max of three minute
unsigned long minOffTime = 60 * 60 * 1000L;  // pump must be off for at least one hour
unsigned long switchDebounceTime = 3 * 1000L;  // Switch must be activated for at least 3 seconds.
unsigned long lastPumpTime = 0;
unsigned long lastLowWaterDetectTime = 0;
boolean lastLowWaterState = HIGH;
boolean pumpRunning = false;
unsigned long currentMillis;
int relayPin = 49;// Heater on ssr1
int relay2Pin = 28;// Cooling to 16ch relay board relay 7 on the board
int relay3Pin = 22;// return pump on relay 1 on the board
int relay4Pin = 23;// Skimmer on relay 2 on the board
int relay5Pin = 24;// Reactor on relay 3 on the board
int relay6Pin = 27;// t5s
int relay7Pin = 26;// fuge light
int relay8Pin = 25;// UV, swapped pin with t5's for testing
int relay9Pin = 29;// leds relay
int wave1Pin = 47;// Wave maker on ssr2
int wave2Pin = 46;// Wavemaker 2 on ssr3
float desiredTemp = 25;// Set this to your desired temp
float tempDiff = 1;// This variable provides a small +/- temp differential that will prevent constant relay switching.
bool      tempAlarmFlag    = false;      //flag to alarm, and avoid multiple Notification
bool      faultyProbeFlag  = false;      //flag to alarm, and avoid multiple Notification
float lowAlarm     = NAN;
float highAlarm    = NAN;
int x;
int y;
int tempfail = 0;
int ledStatus = 0;
bool ONstatusleft  = false;
bool ONstatusright  = false;
int CounterOn = 0;
int CounterOff = 0;
int wavesw = 1;// Wave maker Onoff Button
int heatersw = 1;// Heater Onoff Button
int coolingsw = 1;// Cooling switch
int CurrentPage = 0;  // Create a variable to store which page is currently loaded
char Date[16];
char Time[16];
long startseconds = 0;         // start time in seconds
long stopseconds = 0;          // stop  time in seconds
long nowseconds = 0;           // time  now  in seconds
long fadetimemillis = 0;
int minPWM = 0;// variable for min PWM value. keep at 1 to avoid crashing the ledFade()
int leddimming;
int ledbrighten;
int leddimming1;
int ledbrighten1;
int fadeseconds;
int manualleds = 0;  // button value
byte fadeIncrement = 1; //How smooth to fade? Uses all 4095 steps available.
int fadetime = 0;
int maxPWM0 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int maxPWM1 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int currentFadePosition0 = 0;// don't change this!
int currentFadePosition1 = 0;// don't change this!
unsigned long previousFadeMillis0;// millis() timing Variable, just for fading
unsigned long previousFadeMillis1;// millis() timing Variable, just for fading
long stepWaitTime0 = 0;  //How long to watch the clock before incrementing to the next step. (time in milliseconds)
long stepWaitTime1 = 0;  //How long to watch the clock before incrementing to the next step. (time in milliseconds)
int desiredledLevel0 = 0;
int desiredledLevel1 = 0;
#define led0  2 // white leds on pin...
#define led1  3 // blue leds on pin...
//******************************************************************************************** LED light control*****************************************************************************
void setLed() {
  stepWaitTime0 = (fadetimemillis / maxPWM0);
  stepWaitTime1 = (fadetimemillis / maxPWM1);
terminal.print("current fade position =");
terminal.println(currentFadePosition0);
terminal.print("current fade position1 =");
terminal.println(currentFadePosition1);
void ledbright(){
  if (nowseconds > startseconds && nowseconds < stopseconds) {
      currentFadePosition0 = currentFadePosition0 + fadeIncrement;
      if (currentFadePosition0 >= maxPWM0) {
        // At max limit stop the fade
        currentFadePosition0 = maxPWM0;
      // put actionable () here.
      analogWrite(led0, currentFadePosition0);
 void leddim(){
  if (nowseconds > stopseconds)
      currentFadePosition0 = currentFadePosition0 - fadeIncrement;
      if (currentFadePosition0 <= minPWM) {
        // At min limit stop the fade
        currentFadePosition0 = minPWM;
void ledbright1(){
      currentFadePosition1 = currentFadePosition1 + fadeIncrement;
      if (currentFadePosition1 >= maxPWM1) {
        currentFadePosition1 = maxPWM1;
      analogWrite(led1, currentFadePosition1);
      // reset millis for the next iteration (fade timer only)
 void leddim1(){
      currentFadePosition1 = currentFadePosition1 - fadeIncrement;
      if (currentFadePosition1 <= minPWM) {
        currentFadePosition1 = minPWM;
       Blynk.virtualWrite(V57, LOW);// turns LED relay on
       Blynk.virtualWrite(V58, HIGH);// turns fuge light off
       Blynk.syncVirtual(V58, V57);
// Digital clock display of the time
void clockDisplay(){
  String currentTime = String(hour()) + ":" + minute() + ":" + second();
  String currentDate = String(day()) + " " + month() + " " + year();
  nowseconds = ((hour() * 3600) + (minute() * 60) + second());
  Serial.print("Time =");
  Serial.println(currentTime);
 // Serial.println(currentDate);
  Serial.print("Nowseconds =");
  Serial.println(nowseconds);
 // Serial.print("Start = ");
 // Serial.println(startseconds);
  //Serial.print("Stop = ");
 // Serial.println(stopseconds);
 // Serial.print("fade position0 =");
 // Serial.println(currentFadePosition0);
 // Serial.println();
  // Send time to the App
  Blynk.virtualWrite(V0, currentTime);
  // Send date to the App
  //Blynk.virtualWrite(V2, currentDate);
BLYNK_WRITE(V10) {// slider widget to set the maximum led level from the Blynk App.
  desiredledLevel0 = param.asInt();// channel 1
  maxPWM0 = map(desiredledLevel0, 0, 100, minPWM, 255);
BLYNK_WRITE(V13) {// slider widget to set the maximum led level from the Blynk App.
  desiredledLevel1 = param.asInt();// channel 2
  maxPWM1 = map(desiredledLevel1, 0, 100, minPWM, 255);
BLYNK_WRITE(V14) {// slider widget to set the led fade duration up tp 3 hours.
  fadetime = param.asInt();
  fadeseconds = map(fadetime, 1, 180, 1, 10800);// 3 hour fade duration is max seconds
  fadetimemillis  = map(fadetime, 1, 180, 1, 10800000);// 3 hour fade duration is max
 // Serial.print("Fade Time in seconds =");
 // Serial.println(fadetimeseconds);
void activetoday() {       // check if schedule should run today
  if (year() != 1970) {
    Blynk.syncVirtual(V15); // sync led timeinput widget
    Blynk.syncVirtual(V16);// sync T5s timeinput widget
    sprintf(Date, "%02d/%02d/%04d",  day(), month(), year());
    sprintf(Time, "%02d:%02d:%02d", hour(), minute(), second());
BLYNK_WRITE(V58){ //fuge relay buton
   int fuge = param.asInt(); // Get State of Virtual Button, fuge
  if (fuge == 1) {
     digitalWrite(relay7Pin,LOW);
    digitalWrite(relay7Pin,HIGH);
BLYNK_WRITE(V57){ //leds relay buton
   int ledr = param.asInt(); // Get State of Virtual Button
  if (ledr == 1) {
     digitalWrite(relay9Pin,LOW);
    digitalWrite(relay9Pin,HIGH);
BLYNK_WRITE(V17){ //T5's relay buton
   int tube = param.asInt(); // Get State of Virtual Button, t5s
  if (tube == 1) {
     digitalWrite(relay6Pin,LOW);
    digitalWrite(relay6Pin,HIGH);
BLYNK_WRITE(V18){ //manual auto lights button
   int man = param.asInt(); // Get State of Virtual Button, manual lights
   manualleds = man;
  if (man == 1) {
      timer.disable(ledbrighten);
      timer.disable(ledbrighten1);
      timer.disable(leddimming);
      timer.disable(leddimming1);
      analogWrite(led0, maxPWM0);
     analogWrite(led1, maxPWM1);
         timer.enable(ledbrighten);
      timer.enable(ledbrighten1);
      timer.enable(leddimming);
      timer.enable(leddimming1);
BLYNK_WRITE(V16) {   // T5s
  TimeInputParam t(param);
int startsecond = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
int stopsecond = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
  Serial.println(startsecond);
  Serial.println(stopsecond);
  Serial.println();
  int dayadjustment = -1;
  if(weekday() == 1){
    dayadjustment = 6; // needed for Sunday Time library is day 1 and Blynk is day 7
  if(t.isWeekdaySelected((weekday() + dayadjustment))){ //Time library starts week on Sunday, Blynk on Monday
    //Schedule is ACTIVE today
    if(nowseconds >= startsecond - 31 && nowseconds <= startsecond + 31 ){    // 62s on 60s timer ensures 1 trigger command is sent
      Serial.println("Schedule 1 started");
     Blynk.virtualWrite(V17, HIGH);  // turn on virtual button t5s
     Blynk.syncVirtual(V17);
    if(nowseconds >= stopsecond - 31 && nowseconds <= stopsecond + 31 ){   // 62s on 60s timer ensures 1 trigger command is sent
      Serial.println("Schedule 1 finished");
     Blynk.virtualWrite(V17, LOW);   // turn OFF virtual vutton t5s
BLYNK_WRITE(V15) {// set time for leds
//  Serial.print("Checked schedule at: ");
//  Serial.println(Time);
  if (weekday() == 1) {
    dayadjustment =  6; // needed for Sunday, Time library is day 1 and Blynk is day 7
  if (t.isWeekdaySelected((weekday() + dayadjustment))) { //Time library starts week on Sunday, Blynk on Monday
  //  Serial.println("Schedule ACTIVE today");
    startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
    if (nowseconds >= startseconds) {
      if (nowseconds <= startseconds + 90) {  // 90s on 60s timer ensures 1 trigger command is sent
        // code here
            Serial.println("Schedule 2 started");
           ledbrighten = timer.setTimer(stepWaitTime0, ledbright, maxPWM0);
       ledbrighten1 = timer.setTimer(stepWaitTime1, ledbright1, maxPWM1);
         Blynk.virtualWrite(V57, HIGH);// turns LED relay on
         Blynk.virtualWrite(V58, LOW);// turns fuge light off
    else {
 //     Serial.println("Relay not on");// nothing more to do here, waiting for relay to be turned on later today
    stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
    if (nowseconds >= stopseconds) {
      if (nowseconds <= stopseconds + 90) {
        // code here
          leddimming = timer.setTimer(stepWaitTime0, leddim, maxPWM0);
            leddimming1 = timer.setTimer(stepWaitTime1, leddim1, maxPWM1);
    else {
      if (nowseconds >= startseconds) { // only show if motor has already started today
      //  Serial.println("Relay is still ON");
        // nothing more to do here, waiting for motor to be turned off later today
  else {
  //  Serial.println("Schedule INACTIVE today");
    // nothing to do today, check again in 1 minutes time
void reconnectBlynk() {
  if (!Blynk.connected()) {
    if (Blynk.connect()) {
      BLYNK_LOG("Reconnected");
    else {
      BLYNK_LOG("Not reconnected");
//*****************************************************************************************WAVEMAKERS CONTROLE*****************************************************************************
BLYNK_WRITE(V4){   // wave on time slider
  x = param.asInt();
BLYNK_WRITE(V7){  // wave Off time slider
  y = param.asInt();  // set variable as Slider value
WidgetLED leftled(V68);
WidgetLED rightled(V69);
  void wavecontrol(){
  if((CounterOn > 0)&& (ONstatusleft == true)){
    CounterOn--;    //  reduce Countdown by 1 minute every 60s
  if((CounterOn > 0) && (ONstatusleft == false)){
    ONstatusleft = true;   // to ensure device is only turned ON once
        CounterOff = 0;
         digitalWrite(wave1Pin,HIGH);
         leftled.on();
  if((CounterOn == 0) && (ONstatusleft == true)){
    ONstatusleft = false;    // to ensure device is only turned OFF once
 digitalWrite(wave1Pin,LOW);
leftled.off();
   if ((CounterOff == 0) && (CounterOn == 0))
      CounterOff = x;
 if((CounterOff > 0)&& (ONstatusright == true)){
    CounterOff--;    //
     if((CounterOff > 0) && (ONstatusright == false)){
    ONstatusright = true;   // to ensure device is only turned ON once
        CounterOn = 0;
         digitalWrite(wave2Pin,HIGH);
         rightled.on();
  if((CounterOff == 0) && (ONstatusright == true)){
    ONstatusright = false;    // to ensure device is only turned OFF once
 digitalWrite(wave2Pin,LOW);
rightled.off();
     if ((CounterOn == 0) && (CounterOff == 0))
      CounterOn = y;
  BLYNK_WRITE(V6) // wavemakers
  int wavesw = param.asInt(); // Get State of Virtual Button, wave makers
   if (wavesw == 1) {
    Blynk.virtualWrite(V4,5);
    Blynk.virtualWrite(V7,5);
    Blynk.syncVirtual(V4, V7);
   }else{
    Blynk.virtualWrite(V4,0);
    Blynk.virtualWrite(V7,0);
  BLYNK_WRITE(V60) // left wave button
  int leftwavesw = param.asInt(); // Get State of Virtual Button, wave makers
   if (leftwavesw == 1) {
    Blynk.syncVirtual(V7);
   }else{
  BLYNK_WRITE(V61) // right wave button
  int rightwavesw = param.asInt(); // Get State of Virtual Button, wave makers
   if (rightwavesw == 1) {
    Blynk.syncVirtual(V4);
   }else{
//****************************************************************************************TEMPERATURE CONTROL*******************************************************************************
WidgetLED heaterled(V63);
WidgetLED coolerled(V64);
BLYNK_WRITE(V8){  // heater button
   int heatersw = param.asInt(); // Get State of Virtual Button, heater
BLYNK_WRITE(V9){
  int coolingsw = param.asInt(); // Get State of Virtual Button, cooling
BLYNK_WRITE(V11)
  //reads the setppoint
  desiredTemp = param.asFloat();
BLYNK_WRITE(V12)
  //reads the differential
  tempDiff = param.asFloat();
BLYNK_WRITE(V32){
  //reads low alarm
  lowAlarm = param.asFloat();
BLYNK_WRITE(V33){
  //reads high alarm
  highAlarm = param.asFloat();
void Heater()
   //if sensor not sending temperature turn relay OFF for safety
  if (tanktemp == -127) {
   digitalWrite(relayPin, LOW);
   heaterled.off();
 else if (tanktemp < desiredTemp - tempDiff)
    Serial.print("tanktemper");
    Serial.println(tanktemp);
    Serial.print("desired");
    Serial.println(desiredTemp);
    Serial.print("temp Diff");
    Serial.println(tempDiff);
    digitalWrite(relayPin, HIGH);
   heaterled.on();
 else{
  heaterled.off();
  if (tanktemp >= desiredTemp )
    heaterled.off();
}//--(end Heater )---
void Cooler()
  if (tanktemp == -127.00 && 80)
  digitalWrite(relay2Pin, HIGH);
  coolerled.off();
  else if (tanktemp > desiredTemp + tempDiff)
    digitalWrite(relay2Pin, LOW);
    coolerled.on();
  if (tanktemp < desiredTemp )
    coolerled.off();
  if (tempfail >= 3)
   coolerled.off();
}//--(end Cooler )---
void relaysOn()
    Blynk.virtualWrite(V2, HIGH);// Skimmer
    Blynk.virtualWrite(V3, HIGH);// Reactor
    Blynk.virtualWrite(V6,HIGH);// wavemakers
    Blynk.virtualWrite(V8, HIGH);// Heaters
    Blynk.virtualWrite(V9, HIGH);// cooling
    Blynk.syncVirtual(V2, V3, V6, V8, V9);  // Trigger the associated function for V6 as if you had touched the widget in the App
void take_temp_readings() {
  //Serial.print("Number of Devices found on bus = ");
  //Serial.println(DS18B20.getDeviceCount());
  //Serial.print("Getting temperatures... ");
  //Serial.println();
 // DS18B20.requestTemperatures();
DS18B20.requestTemperaturesByAddress(Probe01);
DS18B20.requestTemperaturesByAddress(Probe02);
   if (tanktemp == -127.00)
    Serial.println("Error getting temperature  ");
    tempfail+1;
void send_data_to_blynk(){
  //tanktemp = DS18B20.getTempCByIndex(0);
   // Get the temperature that you told the sensor to measure
// DS18B20.requestTemperaturesByAddress(Probe01); // Send the command to get temperatures
 tanktemp = DS18B20.getTempC(Probe01);
 //if (tanktemp == -127) {
 //  tempfail+1;
//} else {
  Blynk.virtualWrite(V5, tanktemp); // send tank temp to virtual pin 5
   sumptemp = DS18B20.getTempC(Probe02);
  //sumptemp = DS18B20.getTempCByIndex(1);
 //   if (sumptemp == -127) {
 //    tempfail+1;
//    } else {
  Blynk.virtualWrite(V56, sumptemp); // send sump temp to virtual pin 56
     tempaver = (tanktemp + sumptemp) / 2;
   Blynk.virtualWrite(V70, tempaver); // send average temp to virtual pin 70
   //check alarms;
  if (isnan(tanktemp)){
    if (Blynk.connected() && !faultyProbeFlag)
      Blynk.notify("Probe disconnected");
      Blynk.email("A.bundy1995@hotmail.co.uk", "Aquaruim Controler Alert", "Probe disconnected");
      faultyProbeFlag = true;
  else if ((tanktemp < lowAlarm && !tempAlarmFlag) && (tempfail >= 3)){
    Blynk.notify(String(tanktemp) + "ºC Low temp alarm");
    Blynk.email("A.bundy1995@hotmail.co.uk", "Aquaruim Controler Alert", (String(tanktemp) + "ºC Low temp alarm"));
    tempAlarmFlag = true;
    tempfail = 0;
  else if (tanktemp > highAlarm && !tempAlarmFlag){
    Blynk.notify(String(tanktemp) + "ºC High temp alarm");
    Blynk.email("A.bundy1995@hotmail.co.uk", "Aquaruim Controler Alert", (String(tanktemp) + "ºC High temp alarm"));
  else if (tanktemp > lowAlarm && tanktemp < highAlarm)
  else faultyProbeFlag = false;
//******************************************************************************************ATO Control**************************************************************************************
WidgetLED sumphighled(V65);
WidgetLED sumplowled(V49);
WidgetLED atovalveled(V66);
void ATOcontrol()
  boolean lowWaterState = digitalRead(lowWaterPin);
  boolean highWaterState = digitalRead(highWaterPin);
  if(lowWaterState != lastLowWaterState){
    lastLowWaterDetectTime = currentMillis;
    sumplowled.on();
 if (highWaterState == LOW)
 sumphighled.on();
 else {
 sumphighled.off();
 if (lowWaterState == LOW)
 sumplowled.on();
 else {
 sumplowled.off();
  if (pumpRunning) {  // if the pump is on then let's see if we should turn it off yet
    if ((highWaterState == HIGH) || (currentMillis - lastPumpTime >= maxRunTime)){
      atovalveled.off();
      digitalWrite(pumpPin, LOW);
      lastPumpTime = currentMillis;
  else {   // pump is not running, see if we need to turn it on
      if((lowWaterState == LOW)  && (highWaterState == LOW) && (currentMillis - lastLowWaterDetectTime >= switchDebounceTime) && (currentMillis - lastPumpTime > minOffTime)){   // switch is low and has been for at least 3 seconds
        atovalveled.on();
        digitalWrite(pumpPin, HIGH);
        pumpRunning = true;
  lastLowWaterState = lowWaterState;
//*********************************************************************************************** BUTTON INPUTS ***************************************************************************
BLYNK_WRITE(V3){  // Reactor button off
 int reactor = param.asInt(); // Get State of Virtual Button, Return pump
  if (reactor == 1) {  // button ON
    // Turn as many pins/relays ON as you need
    digitalWrite(relay5Pin, LOW);
  } else {  // button OFF
    // Turn as many pins/relays OFF as you need
    digitalWrite(relay5Pin, HIGH);
BLYNK_WRITE(V2){  // Skimmer button off
 int skimmer = param.asInt(); // Get State of Virtual Button, Return pump
  if (skimmer == 1) {  // button ON
    digitalWrite(relay4Pin, LOW);
    digitalWrite(relay4Pin, HIGH);
BLYNK_WRITE(V62){  // UV button off
 int uv = param.asInt(); // Get State of Virtual Button, Return pump
  if (uv == 1) {  // button ON
    digitalWrite(relay8Pin, LOW);
    digitalWrite(relay8Pin, HIGH);
BLYNK_WRITE(V1){  // Return pump button off
 int value = param.asInt(); // Get State of Virtual Button, Return pump
  if (value == 1) {  // button ON
    digitalWrite(relay3Pin, LOW);
    // bt0.setValue(&number5);
    timer.setTimeout(30000, relaysOn);
    digitalWrite(relay3Pin, HIGH);
    Blynk.virtualWrite(V2, LOW);// Skimmer
    Blynk.virtualWrite(V3, LOW);// Reactor
    Blynk.virtualWrite(V6, LOW);// Wavemakers
    Blynk.syncVirtual(V6);  // Trigger the associated function for V6 as if you had touched the widget in the App
    Blynk.virtualWrite(V8, LOW);// Heating
    Blynk.virtualWrite(V9, LOW);// Cooling
    Blynk.syncVirtual(V9);
BLYNK_WRITE(V38){  // feed button to turn relays off for set time then back on again
  if (value == 1) {  // button Pressed
    Blynk.virtualWrite(V62, LOW);// uv
    Blynk.virtualWrite(V8, LOW);// heaters
    Blynk.virtualWrite(V9, LOW);// cooling
    timer.setTimeout(420000L, relaysOn);// wait for 7 mins before turning everything back on.
    Blynk.virtualWrite(V1, HIGH);
    Blynk.syncVirtual(V1);
void setup()   /****** SETUP: RUNS ONCE ******/
  Serial.begin(9600);  // start serial port to show results
  // run timer every minute to check for led On/Off action
  DS18B20.begin(); // Initialize the Temperature measurement library
  // set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
  DS18B20.setResolution(Probe01, 11);
  DS18B20.setResolution(Probe02, 11);
 // DS18B20.setWaitForConversion(false); // make reading NON blocking
pinMode(relayPin, OUTPUT);
pinMode(relay2Pin, OUTPUT);// Cooling
pinMode(relay3Pin, OUTPUT);//return pump
pinMode(relay4Pin, OUTPUT);// skimmer
pinMode(relay5Pin, OUTPUT);// reactor
pinMode(wave1Pin, OUTPUT);
pinMode(wave2Pin, OUTPUT);
pinMode(relay6Pin, OUTPUT);// t5s declaired
digitalWrite(relay6Pin, HIGH);
pinMode(relay7Pin, OUTPUT);// Fuge light
digitalWrite(relay7Pin, HIGH);
pinMode(relay8Pin, OUTPUT);// UV
pinMode(relay9Pin, OUTPUT);// leds relay
digitalWrite(relay9Pin, HIGH);
pinMode(SDCARD_CS, OUTPUT);
  pinMode(lowWaterPin, INPUT_PULLUP);// ATO
  pinMode(highWaterPin, INPUT_PULLUP);//ATO
  pinMode(pumpPin, OUTPUT);// ATO
  Blynk.begin(auth);  // Here your Arduino connects to the Blynk Cloud.
  timer.setInterval(1000L, clockDisplay);     // digital time displayed every second
  timer.setInterval(1040L, setLed);
  timer.setInterval(1080L, wavecontrol);
  timer.setInterval(1120L, ATOcontrol);
  timer.setInterval(2500L, take_temp_readings);  // Setup a function to be called every second
  timer.setInterval(5000L, send_data_to_blynk);
  timer.setInterval(5100L, Heater);
  timer.setInterval(5200L, Cooler);
  timer.setInterval(60000L, activetoday);     // check every minute if schedule should run today
  timer.setInterval(60200L, reconnectBlynk);  // check every 60s if still connected to server
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
  Blynk.run(); // All the Blynk Magic happens here...
// get the current time, for this time around loop
  // all millis() timer checks will use this time stamp
 currentMillis = millis();
}//--(end main loop )---
//*********( THE END )***********
Going back to the connection issue. I thought i had it covered in this section but it dosnt seen to reconnect.
    else {
#4
For the most part the order positioning of functions is irrelevant to the IDE
#5
All you are doing is checking… you would need to actually initiate a connection attempt with the command Blynk.connect(); not just recheck it (the command can be used for both)
    Blynk.connect();
    else {
#6
Hello Gunner, and thank you for your reply. I made the changes to my code last night but it crashed out at 10am this morning and failed to reconnect. Sadly i didnt have the serial port open so i couldnt check if it tried to reconnect.
Should i try the code in the post you first posted up on here?
Or dos it sound like a hardware issue?
Many thanks
Adam.
#7
I run my Mega with an ESP-01 over WiFi… so my connection routing will work a bit different and you will need to modify for your needs, but this is what I have sitting in my void loop() It is a bit unrefined, but it actually works very well…
  if (Blynk.connected()) {  // If connected run as normal
  } else if (ReCnctFlag == 0) {  // If NOT connected and not already trying to reconnect, set timer to try to reconnect in 60 seconds
    ReCnctFlag = 1;  // Set reconnection Flag
    Serial.println("Starting reconnection timer in 30 seconds...");
    timer.setTimeout(30000L, []() {  // Lambda Reconnection Timer Function
      ReCnctFlag = 0;  // Reset reconnection Flag
      ReCnctCount++;  // Increment reconnection Counter
      Serial.print("Attempting reconnection #");
      Serial.println(ReCnctCount);
      wifi.setDHCP(1, 1, 1); //Enable dhcp in station mode and save in flash of esp8266
      Blynk.config(wifi, auth, server, port);
      Blynk.connect();  // Try to reconnect to the server
      if (Blynk.connectWiFi(ssid, pass)) {
        Blynk.connect();
    });  // END Timer Function
Actually… since you are using Ethernet shield… and I have found them a bit unreliable… you may need to add in something like a forced reboot command.
#8
Hmm i did try a esp 01 but failed to get it working, i think i cooked it im not sure. I did however managed to update it. Resetting the arduino on disconnect wouldnt be practical as it woypd have sode effects to my marine tank. Ill try modifying the code above and see how i get in with that. Failing that, ill have to look into other connectivity options like the esp01 again. But mine just wouldnt do a thing.
Still find it very strange how the arduino dosnt crash when im using it at home, but as soon as i start turning things on and off when im not on the same network, it crashes and disconnects. Im thinking its the ethernet sheild as im sure it never did this before, ever.
#9
It shouldn’t… Between the speed it boots, no strange GPIO issues on boot like the ESP8266 dev boards can have, using Blynk.config() and syncing virtual pins on connection, your tank would never even notice.
#10
Does this happen when you’re at home and turn off Wi-Fi on your phone, so that you’re using mobile data? If so, does your serial monitorgive any clues about what’s happening?
Is there any chance that something else is happening when you’re not at home, like the cat climbing up your Ethernet cable as it tries to help itself to a fish supper?
#12
Thanks for your replies. That laat post tickled me lol. I finally managed to get it to crash. It seems to be when i trigger my heating and cooling Burton’s to the off position :confused: i implemented the code you suppied earlier @Gunner and hasnts disconneted on its own that i knownof since.
I was off the network when it failed.
#13
Scrap that, it just crashed when i tried to turn a relay off and that was while i was on the hime network. Its fustrating because everytime it crashes, so dos my led dimming timers and the current fade position is forgetten so i then have to put the lights into manual for the rest of the day and try to remember to switch it back for the next day :confused:
#14
Iv just managed to get it to fail twice in a row now trying to turn a relay off from the app on my hime network. Theres nothing to upset the connection such as cats etc but it is ran from my ethernet switch in the loft.
Cheers Adam.
#15
So how are you powering your relays? is there any chance that you’re getting a supply voltage dip to your MCU when the relay kicks-in, or could it be an EMF problem?
The relays are powered from a 12v psu. Then i have the ground shared with the 5v left disconnected. The arduino is fed from a second 12v power supplu through a step down to 9v. Then the 2 ds18b20’s run on 3.3v straight from the arduino and i have the resistor on.
I was having issues with EMF when the arduino was powered from the same 12v psu as the arduinos hense the second psu. But the second one is much smaller, maybe the step down is drawing to much, then when the arduino has to trigger the relays, the voltage dips causing the reset?
#17
I think this might be the issue? This is whst im using with a 12v 2amp supply for the arduino. Jusr noticed at the bottom of thr picture it says its not isolated? Could that be it?
#18
It’s certainly worth investigating further. It does sound like you’re getting either a voltage dip/brownout or some sort of noise spikes that are causing your problems.
A while ago I built a gate release controller. The existing mechanism is one of those 12v AC things that makes a buzzing noise when you press the release button and the gate opens.
My controller used an Arduino Mini (since replaced with a Wemos D1 Mini) to control a relay that could also apply 12V AC to the gate release mechanism.
My controller worked fine on the test bench, but when I installed it it wouldn’t work release the gate. It turns out that it was running fine until I got the Arduino to energise the relay then the Arduino would reboot. After lots of head scratching I figured out it must be an EMF problem and tried putting various capacitors across the hot (12v AC) side of the relay to see if that would help. After a bit of experimentation I found a value of capacitor fixed the problem and still allowed the gate release to work.
If you’re switching mains voltages then you might want to think about some mains suppression capacitors across the relays, something like these:
I think its emf. Ill order some of those and give them a go.
One other thing i have noticed us the time sometimes misses a second and looks like its frozen. At one point it was frozen for some hours yet everyrhing seemed to remain operational. I still get the od -127 from either probe to.
Cheers Adam
#20
I think im going ro rewire it all and start again. Ill replace the old relays with ssr’s and seperate the 240v from any low voltage better. Now thinking about, i tried using a stepper motor with this setup before and got a lot of shuddering when the motor should have been locked. Spent hours trying difderent pairs, nothing fixed it. Well i guess the motors where picking up the emf
