Blynk Disconnecting When App is Open
I have a simple DHT11 based temperature and it transmits data and show up in the app, but when the app is connected, it goes through a constant connection/disconnection. See the stream below:
Humidity: 47.00 %	Temperature: 26.00 *C 78.80 *F	Heat index: 25.88 *C 78.59 *F
Humidity: 46.00 %	Temperature: 26.00 *C 78.80 *F	Heat index: 25.86 *C 78.54 *F
[285812] Connecting to blynk-cloud.com:8442
[288249] Ready (ping: 2275ms).
[293251] Login timeout
[295526] Connecting to blynk-cloud.com:8442
[298020] Ready (ping: 2275ms).
[303022] Login timeout
[305297] Connecting to blynk-cloud.com:8442
[307693] Ready (ping: 2276ms).
[312695] Login timeout
Humidity: 46.00 %	Temperature: 25.00 *C 77.00 *F	Heat index: 24.76 *C 76.56 *F
[314970] Connecting to blynk-cloud.com:8442
[317329] Ready (ping: 2275ms).
Humidity: 48.00 %	Temperature: 26.00 *C 78.80 *F	Heat index: 25.91 *C 78.64 *F
You can see precisely where the app opens (and disconnection begins) and where the app is closed.
The code is here:
#include <DHT.h>
#define DHTTYPE DHT11   // DHT 11
#define DHTPIN D4     // what pin we're connected to
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors.  This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "MyAUTH";
char ssid[] = "MySSID";
char pass[] = "MyPass";
float f = 0;
float h = 0;
float t = 0;
// contains initialization
  Serial.setTimeout(1000);
  dht.begin();
  // Wait a few seconds between measurements.
  delay(2000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
 f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(" *F");
  Blynk.virtualWrite(V2,f);
  Blynk.virtualWrite(V3,h);
Any ideas about why this is happening?
Thank you,
Tom
Move everything out of the loop, except Blynk.run(), and put it into a function. Call the function at 2 second intervals with SimpleTimer. You need to do this so Blynk.run() isn’t stopped from running by the massive stall of delay(2000).
Solved, thank you. What delay is acceptable?
Regards,
Tom
As you know, Delay function pauses the program… Try to avoid all delays. Blynk hates them…
@tommyvdp as @psoro has pointed out you should try to avoid all delays. There are actually two issues:
  1. Currently Blynk have a 10s heartbeat timeout, it was previously 5s, and if you miss a heartbeat you WILL be disconnected from the Cloud server. If you run a local server you can change the heartbeat timeout to quite a high figure but that normally means you have written some pretty poor code. Some poor coders might have a 2s delay which goes into a loop and misses the heartbeat.
  2. ESP’s hate delays more than Blynk does as it needs to be doing “WiFi stuff” on a continuous basis.
Personally I try to keep any delays below 200 milliseconds, anything above this is normally called with SimpleTimer.
Not only blynk :smiley: In general such delays must be avoided in a embedded world.
You can setup a counter in you main loop and delay for 1ms, after 2000 count, read the temperature and reset the counter something like
static uint16_t myCounter;
DTHRead();
myCounter++;
delay(1)
if (myCounter > 2000) {
myCounter = 0;
DTHRead();
