Had to build a special actuator and software solution to hide my home cinema screen on top of a shallow but tall book shelf when not in use.
The project make use of Blynk and a ESP8266 for the remote part and a Arduino Nano for most of the PLC logics not because I couldn’t have done it all with a ESP and blynk but just because its fun to mix and learn
Don’t be afraid to teach me, ask questions and/or suggest changes I’m still learning and will do so 4ever!
Full project: https://www.stockholmviews.com/wp/stealth-home-cinema-screen/
Movie of actuator and alpha version in action: https://youtu.be/xdWi0xIxDwM
Blynk part of the code below
char auth[] = "ad8fe2aafd7245f0b76291a1546949d3";
int value;
//int relaypin1 = D5; // example digital pin for relay 1
Blynk.begin(auth, "Timber", "greggan12", "192.168.1.40", 8080);
pinMode (D8, OUTPUT);
pinMode (D7, OUTPUT);
pinMode (D6, OUTPUT);
pinMode (D5, OUTPUT);
pinMode (D2, OUTPUT);
BLYNK_WRITE(V1) {
if (param.asInt() == 1) { // "SCREEN POS 1" act only on the HIGH and not the LOW of the momentary
digitalWrite(D8, !digitalRead(D8)); // invert pin state just once
timer.setTimeout(500L, []() {
digitalWrite(D8, !digitalRead(D8)); // then invert it back after 100ms
Blynk.virtualWrite(V1, LOW);
BLYNK_WRITE(V2) {
if (param.asInt() == 1) { // "SCREEN POS 2" act only on the HIGH and not the LOW of the momentary
digitalWrite(D7, !digitalRead(D7)); // invert pin state just once
digitalWrite(D7, !digitalRead(D7)); // then invert it back after 100ms
Blynk.virtualWrite(V2, LOW);
BLYNK_WRITE(V3) {
if (param.asInt() == 1) { // "SCREEN ROLL UP AND FOLD" act only on the HIGH and not the LOW of the momentary
digitalWrite(D6, !digitalRead(D6)); // invert pin state just once
digitalWrite(D6, !digitalRead(D6)); // then invert it back after 100ms
Blynk.virtualWrite(V3, LOW);
BLYNK_WRITE(V4) { // SCREEN EMERGENCY STOP Set to your Buttons vPin
digitalWrite(D5, !digitalRead(D5)); // Panic STOP on/off
BLYNK_WRITE(V5) {
if (param.asInt() == 1) { // FUTURE FUNCTION act only on the HIGH and not the LOW of the momentary
digitalWrite(D2, !digitalRead(D2)); // invert pin state just once
digitalWrite(D2, !digitalRead(D2)); // then invert it back after 100ms
Blynk.virtualWrite(V5, LOW);
