Blynk connection when pump is connected
I am using arduino mega, 2 soil moisture sensor, 1 DHT11, relay, wifi shield, pump and blynk…
this is my code… i wonder why the blynk connection will not last long is we connected pump… if we only using soil moisture sensor and dht11 (unplug pump wire)… the connection never disconnected.
#define BLYNK_PRINT Serial      //declaration to use Blynk
#include <ESP8266_Lib.h>
#include <DHT.h>
#define DHTPIN 5                // Connect the signal pin of DHT11 sensor to digital pin 5
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
int sensor_pin = A0;  //soil moisture sensor 1
int sensor1 = A1;     //soil moisture sensor 2
int output_value ;  //output value from soil moisture sensor 1
int sensor_value ;  //output value from soil moisture sensor 2
int Pump=13;
char auth[] = " f79df2aeed1945bab751cf4df80f246b"; // Author Token from email
char ssid[] = "TKP Class Room";
char pass[] = "TkpH0lding";
#define EspSerial Serial
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
void sendSensor()
  output_value= analogRead(sensor_pin);
  sensor_value= analogRead(sensor1);
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V6, h);
  Blynk.virtualWrite(V8, t);
  Blynk.virtualWrite(V9, output_value);
  Blynk.virtualWrite(V10, sensor_value);
//Blynk.virtualWrite(V7,  output_value );
void myTimerEvent()
void pump(){
  if(output_value>200||sensor_value>200){
      digitalWrite(Pump,HIGH);
      delay(100);
    if(output_value<140||sensor_value<140){
         digitalWrite(Pump,LOW);
         delay(100);
  dht.begin();
  pinMode(Pump,OUTPUT);
  // Set ESP8266 baud rate
  pump();
  sendSensor();
Sounds like power issue causing the ESP to brown out.
Brown out? So what should i do?
Well, I said “sounds like”… but without knowing exactly how you have everything wired, power ratings of your PSU and pump, and so on… it is just a guess.
Basically use seperate 3.3v PSU for the ESP (do not run it off the Arduino 3.3v pin… it is not good enough), and of course whatever you are running for pumps should have its own separate power as well.
Ohh… i see… i’ll try troubleshoot again… thank you for the clue… :grinning:
