Hi all,
need some help, I’m struggling with Fishino-Blynk connection. Basically the project is simple, writing-reading virtual PINs to get from the APP to switch on/off items and related timer interval.
Typically I get a recurring Connecting to blynk-cloud.com:80 with some errors Packet too big: 55309 and Bad hdr len: 5 with no chance to have “blynk connected”.
• Hardware model + communication type. Fishino UNO (like Arduino UNO+WiFi)
• Smartphone: Android
• Blynk server: Cloud
• Blynk Library version: 0.6.1
• Tryed WIFI and Mobile Hot Spot … same awful result.
Any suggestion?
Thanks a lot!
Here is the sketch code:
http://twitter.com/blynk_app
// Debugging switches and macros
#define DEBUG 1 // Switch debug output 1=on, 0=off
#if DEBUG
#define PRINTS(s) { Serial.print(F(s)); }
#define PRINTSLN(s) { Serial.print(F(s)); Serial.print("\n"); }
#define PRINTV(v) { Serial.print(v); }
#define PRINTVLN(v) { Serial.print(v); Serial.print("\n"); }
#define PRINTSV(s,v) { Serial.print(F(s)); Serial.print(v); }
#define PRINTSVLN(s,v) { Serial.print(F(s)); Serial.print(v); Serial.print("\n"); }
#define BLYNK_PRINT Serial /* Comment this out to disable prints and save space */
#define BLYNK_DEBUG
#define BLYNK_NO_BUILTIN // Disable built-in analog & digital pin operations
#define BLYNK_NO_FLOAT // Disable float on blynk
#else
#define PRINTS(s)
#define PRINTSLN(s)
#define PRINTV(v)
#define PRINTVLN(v)
#endif
//DEFINES REPLACEMENTS ==============================
#define BAUD_RATE 9600
//INCLUDE ==========================================
#include <SPI.h> //required by Blynk
#include <Fishino.h> //requred by Fishino HAL
#include <BlynkSimpleFishino.h> //blynk
#include <WidgetRTC.h> //time server blynk
#include <RTClib.h> //Fishino RTC clock
//WIFI MODULE PARAMETERS ===========================
char MY_SSID[] = "****";
char MY_PASS[] = "*****";
//BLINK VALUES PARAMETERS ===========================
char BLINK_TOKEN[] ="*****";
//RTC DEF ==========================================
//RTC_DS1307 rtc;
char sDtLong[]="2000-12-31 12:12:12";
char sDtShort_DD_MMM_HH_MM[]="01-Gen 12:12";
WidgetRTC rtcServer;
//BLINK TIMER DEF ===========================
boolean isFirstConnect = true;
//EVENT MANAGEMENT
// This function Get Env Data from sensors and sends Arduino's data to Blink.
void FireEvent_GetEnvData_Temperature()
if (1 == 0) { //commented
PRINTSLN("** Temp sensors not connected! **");
Blynk.virtualWrite(V5, "Temp sensors not connected!");
Blynk.notify("Temp sensors not connected!");
//read temp
Blynk.virtualWrite(V0, "temp_water");
Blynk.virtualWrite(V1, "temp_out");
void FireEvent_GetEnvData_PH()
//read PH
double flPH=6.5;
PRINTSVLN(" PH : ",flPH);
Blynk.virtualWrite(V6, String(flPH));
#define INTERVAL_VALUE_LENGTH 14
int iLCDBacklightOnOff = 0;
int iLightsMainEnabled = 0;
int iLightsMainOnOff = 0;
String sLightsMainOnPeriod;
int iLightsSecEnabled = 0;
int iLightsSecOnOff = 0;
String sLightsSecOnPeriod;
int iCO2Enabled = 0;
int iCO2OnOff = 0;
String sCO2OnPeriod;
int iO2Enabled = 0;
int iO2OnOff = 0;
String sO2OnPeriod;
int iDaysToMaint = 14;
int iMaintRefPer = 14;
String SetTimeInput(TimeInputParam lParam,String sItemText, String sPinText) {
char cOnPeriod[INTERVAL_VALUE_LENGTH] ;
if (lParam.hasStartTime() && lParam.hasStopTime())
sprintf(cOnPeriod, "%02d:%02d - %02d:%02d", lParam.getStartHour(), lParam.getStartMinute(), lParam.getStopHour(), lParam.getStopMinute() );
sprintf(cOnPeriod , "--:-- - --:--");
sPinText=String(sPinText+" APP value is: "+String(cOnPeriod));
sItemText=String(sItemText+": interval set");
PRINTVLN(sItemText);
if (!isFirstConnect)
Blynk.virtualWrite(V5, sItemText);
return String(cOnPeriod);
int SetOnOff(int iSwitchOnOff,String sItemText, String sPinText, String sOptionaltext) {
sPinText=String(sPinText+" APP value is: "+String(iSwitchOnOff));
PRINTVLN(sPinText);
if (iSwitchOnOff==0) {
sItemText=String(sItemText+": "+sOptionaltext+" off");
else {
sItemText=String(sItemText+": "+sOptionaltext+" on");
BLYNK_WRITE(V9)
iLCDBacklightOnOff = SetOnOff(param.asInt(),"Luce LCD","V9","");
if (iLCDBacklightOnOff==0) {
//lcd.backlight();
else {
//lcd.noBacklight();
BLYNK_WRITE(V10)
iLightsMainOnOff = SetOnOff(param.asInt(),"Main lights","V10","");
BLYNK_WRITE(V11)
sLightsMainOnPeriod = SetTimeInput(param,"Main lights", "V11");
BLYNK_WRITE(V12)
iLightsMainEnabled = SetOnOff(param.asInt(),"Main lights","V12","timer ");
BLYNK_WRITE(V13)
iLightsSecOnOff = SetOnOff(param.asInt(),"Secondary Lights","V13","");
BLYNK_WRITE(V14)
sLightsSecOnPeriod = SetTimeInput(param,"Secondary Lights", "V14");
BLYNK_WRITE(V15)
iLightsSecEnabled = SetOnOff(param.asInt(),"Secondary Lights","V15","timer ");
BLYNK_WRITE(V16)
iCO2OnOff = SetOnOff(param.asInt(),"C02","V16","");
BLYNK_WRITE(V17)
sCO2OnPeriod = SetTimeInput(param,"C02", "V17");
BLYNK_WRITE(V18)
iCO2Enabled = SetOnOff(param.asInt(),"C02","V18","timer ");
BLYNK_WRITE(V19)
iO2OnOff = SetOnOff(param.asInt(),"Air","V19","");
BLYNK_WRITE(V20)
sO2OnPeriod = SetTimeInput(param,"Air", "V20");
BLYNK_WRITE(V21)
iO2Enabled = SetOnOff(param.asInt(),"Air","V21","timer ");
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.virtualWrite(V5, "Get settings!");
delay(1000*DEBUG);
Blynk.syncAll();
isFirstConnect = false;
Blynk.virtualWrite(V5, "Resync completed!");
delay(1000*DEBUG);
// SETUP FUNCTION ==========================================================================================================================================================================
boolean ReconnectWiFiBlynk() {
// test conncection status
uint8_t stat = Fishino.status();
if(stat != WL_CONNECTED) {
uint32_t connecTime = millis();
uint32_t iRetryTimeOut = 30 * 1000;
while(millis() - connecTime < iRetryTimeOut)
PRINTSLN("Fishino connecting WiFi...");
if(Fishino.begin(MY_SSID, MY_PASS)) {
PRINTSLN("Wifi connected, trying to connect blynk...");
if (ReconnectBlynk()) {
PRINTSLN("Blynk connected!");
PRINTSLN("Blynk not connected, will retry later!");
break;
PRINTS(".");
boolean ReconnectBlynk() {
if(!Blynk.connected()) {
PRINTSLN("Blynk trying to connect...");
Blynk.disconnect();
Blynk.config(BLINK_TOKEN);
while (Blynk.connect() == false) { PRINTS("."); };
if(Blynk.connected()) {
return(true);
break;
PRINTS(".");
// Debug console ******************************************************
#if DEBUG
Serial.begin(BAUD_RATE);
PRINTSVLN("\nDEBUG on serial @",BAUD_RATE);
// Fishino's data ******************************************************
PRINTSLN("Starting Fishino...");
PRINTSVLN(" - Firmware version : ",Fishino.firmwareVersionStr());
PRINTSVLN(" - Free RAM: ",Fishino.freeRam());
#endif
//initialize WIFI and BLINK ***************************************************
SPI.begin();
SPI.setClockDivider(SPI_CLOCK_DIV2);
if(Fishino.reset()) {
PRINTSLN("Fishino WiFi reset ok");
PRINTSLN("Fishino WiFi reset failed");
//connect wifi and blyink
if (ReconnectWiFiBlynk()) {
Blynk.virtualWrite(V5, "AQUABlynk connected!");
delay(500+1000*DEBUG);
PRINTSLN("Connection failed, will retry later!");
timer.setInterval(60000L, ReconnectWiFiBlynk); // check every minute if still connected to server
//initialize RTC ******************************************************
PRINTSLN("RTC...");
// Time widgetRTC synch interval with Blynk server
setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
//fishino RTC start
//rtc.begin();
//if (!rtc.isrunning())
// rtc.adjust(DateTime(year(), month(), day(), hour(), minute(), second())); // <----------------------SET TIME AND DATE: YYYY,MM,DD,HH,MM,SS , year,month, ... get from widgetRTC
sprintf(sDtLong, "[%04d-%02d-%02d %02d:%02d:%02d]", year(),month(),day(),hour(),minute(),second());
#if DEBUG
PRINTSV (" - ",sDtLong);
PRINTSLN (" OK!");
#endif
Blynk.virtualWrite(V5, "RTC: " + String(sDtLong));
delay(1000*DEBUG);
//initialize sensors *******************************************************
timer.setInterval( 10000L, FireEvent_GetEnvData_Temperature); //10sec dev
timer.setInterval( 10000L, FireEvent_GetEnvData_PH); //10sec dev
Blynk.virtualWrite(V5, "Timer impostati!");
delay(1000*DEBUG);
Debug output:
22:06:41.774 -> DEBUG on serial @9600
22:06:41.774 -> Starting Fishino...
22:06:41.806 -> - Firmware version : 7.5.2
22:06:41.840 -> - Free RAM: 405
22:06:42.215 -> Fishino WiFi reset ok
22:06:42.215 -> Fishino connecting WiFi...
22:06:42.521 -> Wifi connected, trying to connect blynk...
22:06:42.556 -> Blynk trying to connect...
22:06:42.590 -> [753] Disconnected
22:06:42.590 -> [774]
22:06:42.623 -> ___ __ __
22:06:42.623 -> / _ )/ /_ _____ / /__
22:06:42.658 -> / _ / / // / _ \/ '_/
22:06:42.693 -> /____/_/\_, /_//_/_/\_\
22:06:42.726 -> /___/ v0.6.1 on Arduino Uno
22:06:42.761 ->
22:06:42.761 -> [932] **Connecting to blynk-cloud.com:80**
22:06:49.092 -> [7329] **Connecting to blynk-cloud.com:80**
22:06:56.104 -> .[14329] **Connecting to blynk-cloud.com:80**
22:06:57.188 -> [15406] <[1D|00|01|00]
22:06:57.188 -> [15408] <**TOKEN**
22:06:57.289 -> [15522] >[00|00|01|00|C8]
22:06:57.289 -> [15523] Ready (ping: 58ms).
22:06:57.323 -> [15523] Free RAM: 316
22:06:57.357 -> [15547] >[CA|14]c[D8|0D]
22:06:57.391 -> [15565] Packet too big: 55309
22:06:57.425 -> [15597] <[11|00|02|00]f
22:06:57.459 -> [15624] <ver[00]0.6.1[00]h-beat[00]10[00]buff-in[00]256[00]dev[00]Arduino Uno[00]cpu[00]ATmega328P[00]con[00]Fishino[00]build[00]May 3 2020 19:19:25[00]
22:06:57.594 -> [15784] Sent 0/107
22:07:02.312 -> [20524] **Connecting to blynk-cloud.com:80**
22:07:02.414 -> [20631] <[1D|00|01|00]
22:07:02.414 -> [20632] <**TOKEN**
22:07:02.515 -> [20732] >[00|00|01|00|C8]
22:07:02.515 -> [20732] Ready (ping: 53ms).
22:07:02.550 -> [20733] Free RAM: 288
22:07:02.583 -> [20799] <[11|00|02|00]f
22:07:02.617 -> [20801] <ver[00]0.6.1[00]h-beat[00]10[00]buff-in[00]256[00]dev[00]Arduino Uno[00]cpu[00]ATmega328P[00]con[00]Fishino[00]build[00]May 3 2020 19:19:25[00]
22:07:02.753 -> [20935] Sent 0/107
22:07:05.092 -> .[25733] **Connecting to blynk-cloud.com:80**
22:07:07.604 -> [25823] <[1D|00|01|00]
22:07:07.604 -> [25824] <**TOKEN**
22:07:07.775 -> [25996] >[00|00|01|00|C8]
22:07:07.775 -> [25996] Ready (ping: 71ms).
22:07:07.809 -> [25997] Free RAM: 260
22:07:07.842 -> [26012] >0[00|00|11|00]
22:07:07.875 -> [26037] Bad hdr len: 5
22:07:07.908 -> [26063] <[11|00|02|00]f
22:07:07.908 -> [26088] <ver[00]0.6.1[00]h-beat[00]10[00]buff-in[00]256[00]dev[00]Arduino Uno[00]cpu[00]ATmega328P[00]con[00]Fishino[00]build[00]May 3 2020 19:19:25[00]
22:07:08.080 -> [26249] Sent 0/107
22:07:12.850 -> [31062] **Connecting to blynk-cloud.com:80**
22:07:12.917 -> [31149] <[1D|00|01|00]
22:07:12.917 -> [31151] <**TOKEN**
