I have a WeMos D1 board with DHT12 and BMP280 sensors attached to it. All the pins are working well, in some cases I do get DHT failed to read.
The problem is everything was working fine and since I connected BMP sensors, the blynk internet communication connection began to cut off at random intervals.
It shows me heartbeat timeout on the serial console and blynk cuts off and reconnects.
I have 5 Virtual pins for reading different sensor data, and all of them are working fine.
#include <Adafruit_BMP280.h>
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#define DHTPIN 12 // what digital pin we're connected to
#define BMP_SCK 13
#define BMP_MISO 4
#define BMP_MOSI 14
#define BMP_CS 5
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
Adafruit_BMP280 bme(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
float pressure; //To store the barometric pressure (Pa)
float temperature; //To store the temperature (oC)
float SLpressure_mB;
int ELEVATION = 0; //PUT HERE THE ELEVATION OF YOUR LOCATION IN METERS
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "the autho key is legit, believe me!";
char ssid[] = "The Empire Strikes back";
char pass[] = "xxx9023xxx";
void myTimerEvent()
Blynk.virtualWrite(V3, dht.readTemperature());
Blynk.virtualWrite(V5, dht.readHumidity());
Blynk.virtualWrite(V4, SLpressure_mB);
Blynk.virtualWrite(V2, ELEVATION);
if (!bme.begin()) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
while (1);
Serial.println("DHTxx test!");
dht.begin();
// Setup a function to be called every 30 seconds
timer.setInterval(30000L, myTimerEvent);
// Wait a few seconds between measurements.
delay(5000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
// Read temperature as Fahrenheit (isFahrenheit = true)
//float f = dht.readTemperature(true);
if (isnan(h) || isnan(t)) {
return;
// Compute heat index in Fahrenheit (the default)
//float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
//float hic = dht.computeHeatIndex(t, h, false);
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print(t);
Serial.println(" *C ");
Serial.print(f);
Serial.print(" *F\t");
Serial.print("Heat index: ");
Serial.print(hic);
Serial.print(" *C ");
Serial.print(hif);
Serial.println(" *F");
//BMP280 SENSOR READINGS
pressure = bme.readPressure();
//temperature = bme.readTemperature();
SLpressure_mB = (((pressure)/pow((1-((float)(bme.readAltitude(1019)))/44330), 5.255))/100.0);
//Print values to serial monitor:
Serial.print(F("Pressure: "));
Serial.print(pressure, 2);
Serial.println(" Pa");
Serial.print("Equivalent Sea Level Pressure: ");
Serial.print(SLpressure_mB, 2);
Serial.println(" mB");
Serial.print(F("Approx altitude = "));
Serial.print(bme.readAltitude(1019)); // this should be adjusted to local forcase
Serial.println(" m");
ELEVATION = bme.readAltitude(1019);
//END BMP280 SENSOR READINGS
I am not sure if the SPI library, does any interference with your libraries. All my Virtual pins are on PUSH interval settings.
Delay should not be an issue. Especially when I do the RUN method with timer set for the execution of writing to the virtual pins. I removed the ONLY one delay of 5 seconds and interruptions continue but now they are not as often. Majority of the serial prints are for console viewing purposes, and I am not seeing the code to be that complicated.
If you have it figured out, then is this topic solved?
Blynk library has timing requirements as it is constantly communicating back and forth the to server… delays (which STOP all processing) need to be avoided whenever possible… particularly ones used just to slow the void loop() down… since a timed function can do that without blocking.
Thus using timed functions instead of dumping everything in the void loop() is considered better programming practice with Blynk (and with other systems as well… but this is the Blynk forum).
Read through all those links I provided, and all the other in the Help Center, to get a better idea of how to properly setup your sketch.
