Program that increases the counter value by 1
The program works normally.
I just want to remember the last counter value when I reconnect to the server.
I think I should use the BLYNK_CONNECTED command
Can you help me?
Please edit your post to add triple backticks at the beginning and end of your code so that iot displays correctly.
Edited to add… @ggkim - you’ve re-visited the forum, since I posted this, but you haven’t taken the opportunity to edit your post as requested, so I’ve removed your unformatted code.
If you still require assistance with this then please edit your original post and insert your correctly formatted code.
