If you use Blynk.config then it’s your responsibility to establish the Wi-Fi connection first, before calling Blynk.config & Blynk.connect.
You can do this with Blynk.connectWiFi(ssid, pass) or use the more conventional WiFi.config and:
if (WiFi.status() != WL_CONNECTED)
WiFi.begin(ssid, pass); // connect to the network
The (probably simpler and much better) alternative is to use @khoih’s library…
