I can’t connect to Blynk cloud
11:06:48.923 → [49102] Redirecting to fra1.blynk.cloud:80
11:06:48.923 → [49104] Connecting to fra1.blynk.cloud:80
It’s up. No issues.
So nobody knows?
Have you tried putting the IP address of fra1.blynk.cloud
(46.101.217.214) in the connection command, and maybe forcing port 443 as well?
I’ll try ASAP.
It’s the first time I had this issue.
Same issue
8:13:03.139 -> ...........wifi Ready IP address: 192.168.0.14
18:13:05.372 -> Signal 60
18:13:05.372 -> [2338]
18:13:05.372 -> ___ __ __
18:13:05.372 -> / _ )/ /_ _____ / /__
18:13:05.372 -> / _ / / // / _ \/ '_/
18:13:05.372 -> /____/_/\_, /_//_/_/\_\
18:13:05.372 -> /___/ v1.0.0-beta.3 on ESP32
18:13:05.372 ->
18:13:05.372 -> [2344] Connecting to 46.101.217.214:443
18:13:10.411 -> [7395] Connecting to 46.101.217.214:443
18:13:15.451 -> [12440] Connecting to 46.101.217.214:443
Why are you running the beta version?
Should be 1.0.0
Same with 1.0.0 ping to 46.101.217.214 is ok
18:18:38.839 -> ...........wifi Ready IP address: 192.168.0.14
18:18:41.043 -> Signal 62
18:18:41.043 -> [2334]
18:18:41.043 -> ___ __ __
18:18:41.043 -> / _ )/ /_ _____ / /__
18:18:41.043 -> / _ / / // / _ \/ '_/
18:18:41.043 -> /____/_/\_, /_//_/_/\_\
18:18:41.043 -> /___/ v1.0.0 on ESP32
18:18:41.043 ->
18:18:41.043 -> [2340] Connecting to 46.101.217.214:443
18:18:46.098 -> [7393] Connecting to 46.101.217.214:443
Did you pay yout internet bill?
Have you tried rebooting your router?
Can you ping fra1.blynk.cloud
Ping is ok
Envoi d’une requête ‘ping’ sur fra1.blynk.cloud [46.101.217.214] avec 32 octets de données :
Réponse de 46.101.217.214 : octets=32 temps=38 ms TTL=54
Réponse de 46.101.217.214 : octets=32 temps=40 ms TTL=54
Réponse de 46.101.217.214 : octets=32 temps=37 ms TTL=54
Have you tried ports 80 and 8080?
with port 8080
18:29:49.542 → [11172] Redirecting to fra1.blynk.cloud:80
18:29:49.542 → [11174] Connecting to fra1.blynk.cloud:80
I tried remotely at my office with an RDP connection, same issue
18:34:33.999 → [263560037] Connecting to fra1.blynk.cloud:80
18:34:33.999 → [263560107] Redirecting to fra1.blynk.cloud:80
Now it works without changing anything
I told you you needed to pay your internet bill on time!
Good to know I’m not the only one with random cloud connection issues.
@parrot @Blynk_Coeur what is your location (country) and what hardware do you use? Are you able to try ssl connection?
@Blynk_Coeur is in France and lt looks like @parrot is in the USA (based on his/her IP address when accessing the forum).
I had no problem today, everything is working fine.
I’m in the USA. I’m working with the Arduino MKRNB1500.
