Running a very simple program on Particle Photon - below.
Using an Analog input A0 to display a gauge on Blynk, the code runs great about 1/2 hour, then for no reason I can find the Analog input on the Particle goes low impedance (like a it was switched to a Digital output and sent low). This is verified with a DMM. So the analog readings are very low after this event. A reset of the Particle board usually fixes this for a few minutes, not always. Other programs on the Particle without Blynk work fine - Tinker for example
Using Blynk library 0.3.8, Particle Photon using 0.5.2
```// This #include statement was automatically added by the Particle IDE.
#include "blynk/blynk.h"
char auth[] = "771825b75e0c4177874595*******";
delay(5000);
Blynk.begin(auth);
Blynk seems to be freezing the Analog input on my Electron. It used to work fine until 2 days ago.
When I connect photo resistor to any of the analog pin, it works well for a few seconds, then the value will change to between 240 and 260 and will remain there, even if i remove the photo resistor. If I change to another analog pin, it will work for a few seconds and the scenario repeats itself.
If I remove Blynk code and make use of only particle sketch to read the analog pin, it works fine. I even used a fresh Blynk code from the library without any modification, the issue persists.
@vshymanskyy, I was running on firmware version 0.5.2. I just upgraded the device firmware to 0.6.0 and also updated the apps build firmware to 0.5.3 and the analog reading is now working fine.
I discovered that when I upgraded the build firmware to 0.6.0, the Blynk apps was showing “Your particle Electron not in network”, I had to downgrade to 0.5.3 for it to connect.Does this mean that Blynk doesn’t support Firmware Build version 0.6.0 yet?
@vshymanskyy, I used this code with the 0.5.2 build, but I was having the same issue, the same code is working fine with build 0.5.3:
BLYNK_READ(V6) // Widget in the app READs Virtal Pin V6 with the certain frequency
int analogPin = A0; // light sensor connected to analog pin A0
int val = 0; // variable to store the read value
val = analogRead(analogPin); // read the analogPin
Blynk.virtualWrite(6, val ); //writes the value of A0 to V6
Is there any other way I could have used the Virtual Pin?
Yes I had a widget also referring to A0. But when I thought this could be causing the issue, I removed my code and used only 01_Particle Library without any modification, I then only used A0 on the blynk apps without using any Virtual PIn, but the situation persisted.
@vshymanskyy, the issue was resolved immediately i upgraded to Build firmware version 0.5.3, so I think it’s the 0.5.2 that was having the issue.
I’m having a widget using A0 and it is also mapped to V6 using code, and I used another widget to read V6, and didn’t declare A0 as input. Both A0 and V6 are showing same result on widget, and doesn’t give wrong value like before since I upgraded to 0.5.3
