Blynk - C++ Pico-W
I could be the very first asking this but I would like to use Blynk library with pico-w without the Arduino IDE. I am using cmake for building the project and would like to integrate Blynk. But from what I see, I do not see rp2040 directly supported as a standalone board. I would have to use Arduino IDE library management, has anyone else attempted doing so and is it worth it ?
BlynkSimpleWiFi doesn’t work?
No. The codebase is designed to work within Arduino core library. No access to directly instead use Pico’s low level wifi driver calls.
I have tried to add source files in my project but build errors allover the place for assuming Arduino’s core API integration
