#include <MFRC522.h>
#include <WiFiClient.h>
//***** KABLOSUZ AYARLARI *******
char auth[] = "auth";
const char* ssid = "wifiname";
const char* pass = "pass";
//*********IFTTT****************
const char* server = "maker.ifttt.com";
// Kişiye özel IFTTT Url'i
const char* resource = "/trigger/logger/with/key/auth";
//*********** RFID **************
#define RST_PIN D8
#define SS_PIN D4
#define relay D3
#define button D8
MFRC522 mfrc522(SS_PIN, RST_PIN);
String readCardId = ""; // okunan kart idsi
String tempid = ""; // değişken kart idsi
//******** Led Pins and Button Pin *************
#define green D1
#define red D0
#define yellow D2
unsigned long lastTime = 0;
unsigned long lastTime1 = 0;
unsigned long lastTime2 = 0;
unsigned long delayTime = 10000;
unsigned long delayTime1 = 2000;
unsigned long delayTime2 = 10000;
bool find = false;
WiFiClient client;
//***** ANAHTAR LİSTESİ ***********
String Key_list[11][2] = // Anahtar Listesi
{"name","cardid"},
{"name","cardid"},
{"name", "cardid"},
{"name","cardid"},
{"name","cardid"},
{"name","cardid"},
{"name","cardid"},
{"name","cardid"},
{"name","cardid"},
{"name","cardid"},
{"name","cardid"}
// Google tablolar ile bağlantı sağlayan fonksiyon
void connectGoogleSheets()
int retries = 8;
while(!!!client.connect(server, 80) && (retries-- > 0)) {
Serial.print(".");
// IFTTT web servisine bir http isteği gönderir.
void makeIFTTTRequest(String name_surname,String kart_id,String durum) {
digitalWrite(red,HIGH);
Serial.print(server);
int retries = 5;
Serial.print(".");
Serial.println();
if(!!!client.connected()) {
Serial.println("Failed to connect...");
Serial.print("Request resource: ");
Serial.println(resource);
String jsonObject = String("{\"value1\":\"") + name_surname + "\",\"value2\":\"" + kart_id
+ "\",\"value3\":\"" + durum + "\"}";
client.println(String("POST ") + resource + " HTTP/1.1");
client.println(String("Host: ") + server);
client.println("Connection: close\r\nContent-Type: application/json");
client.print("Content-Length: ");
client.println(jsonObject.length());
client.println();
client.println(jsonObject);
int timeout = 5 * 10; // 5 seconds
while(!!!client.available() && (timeout-- > 0)){
delay(100);
if(!!!client.available()) {
Serial.println("No response...");
while(client.available()){
Serial.write(client.read());
Serial.println("\nclosing connection");
client.stop();
digitalWrite(red,LOW);
String getID()
digitalWrite(green,HIGH);
delay(200);
readCardId = "";
if(!mfrc522.PICC_IsNewCardPresent())
return "";
if(!mfrc522.PICC_ReadCardSerial())
return "";
for(int i = 0; i < mfrc522.uid.size;i++)
readCardId += String(mfrc522.uid.uidByte[i],HEX);
Serial.println(readCardId);
digitalWrite(green,LOW);
return readCardId;
void openDoor() // Kapı aç metodu kapı otomatiğini 200 milisaniye açıyor ve kapatıyor.
digitalWrite(relay,HIGH);
delay(200);
digitalWrite(relay,LOW);
void decision() //Karar fonksiyonu ile gelen kart id'nin kararı verilir.
for(int count=0;count<11;count++)
if(Key_list[count][1] == tempid)
Serial.print(Key_list[count][0]);
// Serial.println(" Adli kisi giris yapti.");
openDoor();
if(Blynk.connected()) makeIFTTTRequest(Key_list[count][0],Key_list[count][1],"Açıldı.");
tempid = "";
break;
if(tempid != "")
if(Blynk.connected()) makeIFTTTRequest("Bilinmeyen Kullanici",tempid,"Açılmadı.");
delay(250);
BLYNK_WRITE(V2)
int pinData = param.asInt();
if(pinData == 1){
openDoor();
makeIFTTTRequest("Google Asistan","Kartız","Açıldı.");
Serial.begin(9600); // Seri haberleşmeyi başlatıyoruz.
SPI.begin(); // Spi haberleşme başlatıldı.
mfrc522.PCD_Init(); // Rfid modül başlatıldı.
// röle,ledler,ve buton için giriş çıkış atandı.
pinMode(relay,OUTPUT);
pinMode(green,OUTPUT);
pinMode(red,OUTPUT);
pinMode(yellow,OUTPUT);
pinMode(button,INPUT);
Blynk.begin(auth,ssid,pass); //Blynk başlatıldı.
unsigned long nowTime = millis();
unsigned long nowTime1 = millis();
unsigned long nowTime2 = millis();
if (nowTime - lastTime >= delayTime)
lastTime = nowTime;
if(WiFi.status() != WL_CONNECTED) digitalWrite(yellow,LOW);
else digitalWrite(yellow,HIGH);
if(nowTime1 - lastTime1 >= delayTime1)
lastTime1 = nowTime1;
if(digitalRead(button) == true){
Blynk.notify("Bina içersindeki kapıdan bir kişi kapı açma isteği gönderdi.");
else digitalWrite(red,LOW);
if(nowTime2 - lastTime2 >= delayTime2) // 30 dakikada bir google tablolar ile bağlantı sağlanıyor.
lastTime2 = nowTime2;
connectGoogleSheets();
tempid = getID(); //kart üzerinde okunan kart id tempid değişkenine atılır.
decision(); // karar metodu ile kapının açılıp açılmayacağı kararı verilir.
My full codes
