Blynk arduino usb npt working whwn we add a button
#define BLYNK_PRINT SwSerial
SoftwareSerial SwSerial(0, 1); // RX, TX
SwSerial.begin(1000000);
Blynk.begin(Serial, auth);
// to avoid delay() function!
You’re going to have to provide more information. I’d start with the info you were asked to provide when you created the topic:
- Add details :
• Blynk Library version
Also, you’ve chosen a non-standard baud rate for your serial and SoftwareSerial connections. Why is this?
You are currently using the same pins for both the Serial connection to your PC, and your debug serial connection, which won’t work.
Do you actually have a TTL to Serial (FTDI) adapter available? If not, then the SoftwareSerial and debug serial code can be removed.
9600 is too slow 128000 is comparately fast
and also serial connection stops for 5 sec
I have absolutely no idea why you felt it necessary to create 6 separate posts to answer these questions!
Are you going to respond to this:
And this:
I have no idea what you mean by this, especially as you are using 1000000 as your baud rate.
If you do wish to use SoftwareSerial for debugging then it won’t support baud rates higher than 9600 on the Uno.
yes sir after removing that from my code it is working fine
Thank you sir
Bandwidth and baud rates are entirely different things.
The problem with SoftwareSerial is that it is using a software library to emulate a hardware serial port. This is never going to be as efficient as using an actual hardware port, and the primary limiting factor is the processing power of the board. In the case of the Uno, this is extremely under-powered.
If you want to use SoftwareSerial serial effectively with Blynk on an Uno then the maximum reliable baud rate is 9600.
