Blynk arduino uno Rev 2 wifi invalid auth token
Morning,
Just getting started with Blynk and Arduino Uno Rev 2 WiFi and receiving the “invalid auth token” in the serial monitor.
Using IDE 2 and Blynk 1.1.0
Hoping that you may be able tlo suggest a solution that I can try, please.
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example shows how to use Arduino MKR 1010
  to connect your project to Blynk.
  Note: This requires WiFiNINA library
    from http://librarymanager/all#WiFiNINA
#define BLYNK_TEMPLATE_ID "TMPLqdKWjlKO"
#define BLYNK_DEVICE_NAME "Arduino"
#define BLYNK_AUTH_TOKEN "Qbu6Z8dTKWwLsi81NIwRqEbtKoX0XLXB"
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID   "YourTemplateID"
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char auth[] = "YOUR_AUTH_TOKEN";
char ssid [] = "xxxxxxxxxx";
char pass [] = "xxxxxxxxxx";
  //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
Message (Enter to send message to 'Arduino Uno WiFi Rev2' on 'COM4')
No Line Ending
9600 baud
11:52:39.197 -> [759] Connecting to Tenrings
11:52:40.908 -> [2505] IP: 192.168.0.136
11:52:40.940 -> [2506]
11:52:40.940 ->     ___  __          __
11:52:40.972 ->    / _ )/ /_ _____  / /__
11:52:41.004 ->   / _  / / // / _ \/  '_/
11:52:41.004 ->  /____/_/\_, /_//_/_/\_\
11:52:41.037 ->         /___/ v1.1.0 on Arduino UNO WiFi Rev2
11:52:41.101 ->
11:52:41.101 ->  #StandWithUkraine    https://bit.ly/swua
11:53:17.081 -> [38903] Invalid auth token
11:53:34.769 -> [56682] Connecting to blynk.cloud:80
11:53:35.078 -> [56913] Invalid auth token
11:53:52.699 -> [74682] Connecting to blynk.cloud:80
11:53:52.731 -> [74744] Invalid auth token
Sharing the text from the serial monitor would be a good start.
Also, making these three lines the very first slimes of your sketch is also a very good idea…
I assume that these lines of code were copied and pasted from the device info screen rather than being re-typed?
Morning Pete,
Thanks for the speedy reply. Yes, you are correct in that I copied and pasted all of the code and the information from the serial monitor into the submission. I believe that if you scroll down on my post, it should show the serial monitor info.
I did not include the first few lines as these are all the information lines and I did not know if they would be of any help, but I will go back into the sketch and add these.
I have now added the ommited lines.
