Hi. This is my first time using Blynk and it always shows that my device is not yet online.
So these are the hardware I’m using:
- Arduino Uno (connected to PC using USB cable)
- GPRS Shield V3.0 SIM900 (connected to Arduino, powered by external 5VDC power source)
I’ve also updated both the Blynk app and Blynk library (1.0.0_beta.3). I’ve searched for similar problems regarding “device wasn’t online yet”, and tried similar examples but it just never worked for me.
#define BLYNK_PRINT Serial /* Comment this out to disable prints and save space */
#define TINY_GSM_MODEM_SIM900 // Default heartbeat interval for GSM is 60
#include "DHT.h" //for DHT21 sensor
#include <TinyGsmClient.h>
char auth[] = "";
char apn[] = "";
char user[] = "";
char pass[] = "";
SoftwareSerial SerialAT(2, 3); // RX, TX (Software Serial on Uno)
TinyGsm modem(SerialAT);
#define DHTPIN 13 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature(); // Read temperature as Celsius (the default)
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.println(F("%"));
Serial.print(F("Temperature: "));
Serial.print(t);
Serial.println(F("°C "));
Blynk.virtualWrite(V5, t);
Blynk.virtualWrite(V6, h);
// Set GSM module baud rate
SerialAT.begin(9600);
modem.restart();
This is what shows in the serial port:
23:16:06.968 -> Initializing modem...
23:16:17.002 -> [11022]
23:16:17.002 -> ___ __ __
23:16:17.002 -> / _ )/ /_ _____ / /__
23:16:17.049 -> / _ / / // / _ \/ '_/
23:16:17.102 -> /____/_/\_, /_//_/_/\_\
23:16:17.102 -> /___/ v1.0.0-beta.3 on Arduino Uno
23:16:17.149 ->
23:16:17.149 -> [11123] Modem init...
23:16:27.127 -> [21156] Cannot init
Could anyone please help to tell me which part did I do wrong? I really appreciate your help.
