OK ensure you are using /pin/ and send me the key.
I think if you are blocked for more than 10 failed calls it does eventually unlock but I’m not sure how long the wait period is. Even though iOS might not have the Run Test option it might unlock by simply changing the url to the correct one i.e. /pin/ (not //pin/).
Ok thanks again PAul, I will change the setting tomorrow and do some tests again. So normally the system should unlock itself after some time ? I will switch it off tonight.
AFAIK the Blynk lock sometimes stays on for months. It checks for a valid url and if the provider is accepting your calls. Not sure what the official procedure is for unlocking other than the Run Test with an Android device.
The problem is Paul that I can’t seem to be able to define a specific timing for the webhook. As I want “Live” data in Blynk (eg every second) and a different timing for sending the data to TS (every 30 sec or so) this needs to be done manually with code and here the webhook, function cannot be useed, right ?
