Thanks @Gunner @PeteKnight at the end it’s happy ending device successfully connect as engineer I need to stay on the field, the issue was it wasn’t getting connected to custom port 8088 where I had programmed earlier and was working fine but faced issue recently, on changing to default 8080 thing on track, so blynk doesn’t allow changing port in latest release ? Thanks once again
You can custom design WAN side port via port forwarding, but the Local Server requires 8080 (on the LAN side).
Marking this topic as solved.
