I’m not familiar with that widget.
I think your issue is your code.
i mean button, but what if i want to use the joystick to steer a car but if the values dont change the car will stop driving?
Not if you write your code correctly. The value from the joystick should be stored in a variable and sent to the controller as needed.
But that has to be in the loop then, and ive heard that blynk people dont like code in the loop?
No, if you need something to repeat then you can use a timer.
A lot depends on the hardware you are using and the libraries you are using to control that hardware.
As you’ve not shared any information on those things you’re unable to get any significant pointers from the forum members.
Maybe you should try searching the forum for other people that are using the same hardware and libraries?
Hi part of my project is a line follower, this code is the control with a joystick, which works fine, and tuning the PID parameters while it is driving. I only want to make it to follow a line when a virtual button is switched on, yes it is on switch not hold, because of the size of the car. The problem is that it oly moves for a fraction of a second when it turn the button on. Does anyone know why?
Alse when i toggle the button my project disconect and reconnects again realy fast, this happens everythime.
It is a nodemcu that gets enough current sot that is not the problem.
char auth[] = "4ccb3ce22f794f34a9dfb44208843a20";
char ssid[] = "telenet-apn-497da";
char pass[] = "bscso5zxhoeg";
int sensor[5]; //maak een array met 5 variabelen
int gewenste_snelheid;
int PWM_links = D3; // pwm h-brug links
int PWM_rechts = D4; //pwm h-brug rechts
int snelheid_links; // snelheid linker motor
int snelheid_rechts;// snelheid rechter motor
int DIR_links = D0; //direction pin h-brug links
int DIR_rechts = D8;//direction pin h-brug rechts
void lees_sensorwaarden(void);
void bereken_PID(void);
void motor_control(void);
double x, y, abswx, abswy;
double Kp, Ki, Kd;
double Setpoint, Input, PID_waarde;
int error;
PID myPID(&Input, &PID_waarde, &Setpoint, Kp, Ki, Kd, DIRECT);
int startknop;
void rechtdoor(){
digitalWrite(DIR_links, LOW);
digitalWrite(DIR_rechts, LOW);
void achteruit(){
digitalWrite(DIR_links, HIGH);
digitalWrite(DIR_rechts, HIGH);
void rechts(){
void links(){
BLYNK_WRITE(V0) //Geeft Kp, Ki, Kd, de waarden die in de Blynk app ingevoerd worden
Kp = param.asInt();
BLYNK_WRITE(V1)
Ki = param.asInt();
BLYNK_WRITE(V2)
Kd = param.asInt();
BLYNK_WRITE(V3)
startknop = param.asInt();
BLYNK_WRITE(V6) {
x = param[0].asInt();
y = param[1].asInt();
abswx = abs(x);
abswy = abs(y);
if(x<300 && x>-300 && y>0){ //rechtdoor
rechtdoor();
analogWrite(PWM_links, y);
analogWrite(PWM_rechts, y);
Serial.println("rechtdoor");
else if(x<300 && x>-300 && y<0){//achteruit
achteruit();
analogWrite(PWM_links, abswy);
analogWrite(PWM_rechts, abswy);
Serial.println("achteruit");
else if(y<300 && y>-300 && x>0){//rechts
rechts();
analogWrite(PWM_links, x);
analogWrite(PWM_rechts, x );
Serial.println("rechts");
else if(y<300 && y>-300 && x<0){//links
links();
analogWrite(PWM_links, abswx);
analogWrite(PWM_rechts, abswx);
Serial.println("links");
else{
analogWrite(PWM_links, 0);
analogWrite(PWM_rechts, 0);
BLYNK_WRITE(V8)
gewenste_snelheid = param.asInt();
pinMode(D1, INPUT);
pinMode(D2, INPUT);
pinMode(D5, INPUT);
pinMode(D6, INPUT);
pinMode(D7, INPUT);
pinMode(PWM_links, OUTPUT); //PWM Pin Links
pinMode(PWM_rechts, OUTPUT); //PWM Pin Rechts
pinMode(DIR_links, OUTPUT); //DIR Links
pinMode(DIR_rechts, OUTPUT); //DIR rechts
Input = error;
Setpoint = 0;
myPID.SetMode(AUTOMATIC); //PID regelaar aanzetten
Blynk.begin(auth, ssid, pass); //verbind met de Blynk server via internet
void loop(){
if(startknop==HIGH){
lees_sensorwaarden();
bereken_PID();
motor_control();
void lees_sensorwaarden()
sensor[1] = digitalRead(D1);
sensor[2] = digitalRead(D2);
sensor[3] = digitalRead(D5);
sensor[4] = digitalRead(D6);
sensor[5] = digitalRead(D7);
if ((sensor[1] == 1) && (sensor[2] == 1) && (sensor[3] == 1) && (sensor[4] == 1) && (sensor[5] == 0))
error = 4;
else if ((sensor[1] == 1) && (sensor[2] == 1) && (sensor[3] == 1) && (sensor[4] == 0) && (sensor[5] == 0))
error = 3;
else if ((sensor[1] == 1) && (sensor[2] == 1) && (sensor[3] == 1) && (sensor[4] == 0) && (sensor[5] == 1))
error = 2;
else if ((sensor[1] == 1) && (sensor[2] == 1) && (sensor[3] == 0) && (sensor[4] == 0) && (sensor[5] == 1))
error = 1;
else if ((sensor[1] == 1) && (sensor[2] == 1) && (sensor[3] == 0) && (sensor[4] == 1) && (sensor[5] == 1))
error = 0;
else if ((sensor[1] == 1) && (sensor[2] == 0) && (sensor[3] == 0) && (sensor[4] == 1) && (sensor[5] == 1))
error = -1;
else if ((sensor[1] == 1) && (sensor[2] == 0) && (sensor[3] == 1) && (sensor[4] == 1) && (sensor[5] == 1))
error = -2;
else if ((sensor[1] == 0) && (sensor[2] == 0) && (sensor[3] == 1) && (sensor[4] == 1) && (sensor[5] == 1))
error = -3;
else if ((sensor[1] == 0) && (sensor[2] == 1) && (sensor[3] == 1) && (sensor[4] == 1) && (sensor[5] == 1))
error = -4;
else if ((sensor[1] == 1) && (sensor[2] == 1) && (sensor[3] == 1) && (sensor[4] == 1) && (sensor[5] == 1))
if (error == 4) error = 5;
else if ( error == 5) error = 5;
else error = -5;
// als geen enkele sensor de lijn ziet (van de lijn af) zal de error 5 of 5 worden afhankelijk aan welke kant de sensor het laatst gezien is
void bereken_PID(){
myPID.SetTunings(Kp, Ki, Kd);
myPID.Compute(); //berekent PID_waarde
void motor_control() {
// Motorsnelheid berekenen
int snelheid_links = gewenste_snelheid - PID_waarde; //PID_waarde zal negatief zijn als de error negatief is
int snelheid_rechts = gewenste_snelheid + PID_waarde;
constrain(snelheid_links, 0, 1023); // begrens de snelheid tot de maximale PWM waarde
constrain(snelheid_rechts, 0, 1023);
analogWrite(PWM_links, snelheid_links); //Links Motor snelheid
analogWrite(PWM_rechts, snelheid_rechts); //Rechts Motor Snelheid
digitalWrite(DIR_rechts, LOW); // zorg dat de motoren vooruit draaien
I’d suggest that you edit your post (using the pencil icon at the bottom of the post) and remove the duplications, then add some explanation about which virtual button it is that you’re having difficulty with.
Ifs it is a button on the app then do you have it set to switch or push (I think you need switch)
@Timchone Please do not create multiple topic concerning similar issues… I merged them both together.
Thanks but that is not the problem.
And we won’t understand what the problem is unless you provide some explanation about which button it is that you’re having difficulty with, and what you’re trying to achieve (in more detail than you’ve already provided).
Hi all, I have done a couple of projects with Blynk and i really like it, but im struggeling mith my current one. Is it possible to make a virtual button that switches everything on and off?
It depends what “everything is”… if it is connected to your device you can do virtual write that turns pin1 low, pin2 low, and so on however many pins you have.
I have a car that has 3 modes, one is moving it whith the joystick and this works and the other one is following a line while the button is on. Now the only thing that happens is my nodemcu disconnecting and connecting again when changing that button state. Any ideas?
#include <PID_v1.h>
double Kp, Ki, Kd;
int error;
int startknop;
void rechtdoor(){
void achteruit(){
void rechts(){
void links(){
Kp = param.asInt();
BLYNK_WRITE(V1)
Ki = param.asInt();
BLYNK_WRITE(V2)
Kd = param.asInt();
BLYNK_WRITE(V3)
BLYNK_WRITE(V6) {
abswx = abs(x);
abswy = abs(y);
rechtdoor();
achteruit();
rechts();
links();
else{
BLYNK_WRITE(V8)
pinMode(D1, INPUT);
pinMode(D2, INPUT);
pinMode(D5, INPUT);
pinMode(D6, INPUT);
pinMode(D7, INPUT);
Input = error;
Setpoint = 0;
void loop(){
bereken_PID();
motor_control();
if ((sensor[1] == 0) && (sensor[2] == 0) && (sensor[3] == 0) && (sensor[4] == 0) && (sensor[5] == 1))
error = 4;
else if ((sensor[1] == 0) && (sensor[2] == 0) && (sensor[3] == 0) && (sensor[4] == 1) && (sensor[5] == 1))
error = 3;
else if ((sensor[1] == 0) && (sensor[2] == 0) && (sensor[3] == 0) && (sensor[4] == 1) && (sensor[5] == 0))
error = 2;
else if ((sensor[1] == 0) && (sensor[2] == 0) && (sensor[3] == 1) && (sensor[4] == 1) && (sensor[5] == 0))
error = 1;
else if ((sensor[1] == 0) && (sensor[2] == 0) && (sensor[3] == 1) && (sensor[4] == 0) && (sensor[5] == 0))
error = 0;
else if ((sensor[1] == 0) && (sensor[2] == 1) && (sensor[3] == 1) && (sensor[4] == 0) && (sensor[5] == 0))
error = -1;
else if ((sensor[0] == 0) && (sensor[2] == 1) && (sensor[3] == 0) && (sensor[4] == 0) && (sensor[5] == 0))
error = -2;
else if ((sensor[0] == 1) && (sensor[1] == 1) && (sensor[2] == 0) && (sensor[3] == 0) && (sensor[5] == 0))
error = -3;
else if ((sensor[0] == 1) && (sensor[1] == 0) && (sensor[2] == 0) && (sensor[3] == 0) && (sensor[5] == 0))
error = -4;
else if ((sensor[0] == 0) && (sensor[1] == 0) && (sensor[2] == 0) && (sensor[3] == 0) && (sensor[5] == 0))
if (error == -4) error = -5;
else error = 5;
Input = error;
void bereken_PID(){
Which button state?
Yep. You have too much stuff in the loop().
void loop(){
bereken_PID();
motor_control();
Bit of a crappy thing to do, creating a new account (if you’re the same person - if not then I apologise)
But try commenting out each of the functions and see if the problem still exists.
void loop(){
bereken_PID();
//motor_control();
I think maybe motor control and if so then maybe a problem with an output.
Identical code, down to the auth, ssid and password.
@Toro_Blanco, well spotted!
Both accounts also registered and posting from the same IP address.
I’ve messaged both users and asked for an explanation, if I don’t get a credible response then I’ll deactivate both accounts.
Thanks @Toro_Blanco
Yes, this same user was previously posting same question in another topic as he/she didn’t seem happy with the initial answers… I guess he/she figured this was a way of “outsmarting” us
I have merged both topics together.
