Hi!
I am having some trouble with my current project. I use:
-Arduino Uno with Ethernet Shield
-Smartphone OS (iOS 14.1)
-Blynk server
I periodically send data to server via virtual pins. In my app I have four Gauges, data to three of them is pushed periodically using the virtual write function. It works without problems. The fourth gauge does not work like the other ones. I have a slider sending values 1-4 to device (V0) and the device answers on V1. This also works. But the problem I have is that when starting Blynk app on iPhone, the value of the fourth slider is not updated, the other ones are. Instead I have temporarily added some ugly periodic update with virtual write of V1. Then it works, but I suppose that when writing the value of V1 to server, that should be read by app? My feeling is that I have missed something here
Best regards Björn
Styrning av värmepump
// Blynk-items
#define BLYNK_TEMPLATE_ID "123" (Masked)
#define BLYNK_DEVICE_NAME "Test"
#define BLYNK_AUTH_TOKEN "ABC" (Masked)
#include <Ethernet.h>
#include <EEPROM.h>
// Ethernet shield
#define W5100_CS 10
#define SDCARD_CS 4
// Uppstartsfördröjning START_DELAY * 1 s
// Ska sättas till 60 sekunder när systemet är live
// Routern verkar hitta koppling efter cirka 35 sekunder
#define START_DELAY 10
// Används för periodisk koll
BlynkTimer periodicTimer, ledTimer;
// Räknare för antalet checkar mot cloud
// Kör varje minut
// LĂĄt dem nollas vid omstart
unsigned int connected = 0;
unsigned int not_connected = 0;
// Räknare för periodisk timer
int periodicCount = 0;
// Antal minuter - periodtid
const int period = 60;
// EEPROM-struktur
//Address Parameter
// 0 Level, indikator
// 1 Level
// Virtuella pinnar
// Sätta temperaturnivå : V0
// Visa temperaturnivĂĄ : V1
// Hall : V2
// Utomhus : V3
// Vardagsrum : V4
// Uppkoppling stat. : V5
// Om pinne V0 (slider) ändrats, spara nivå persistent och sätt reläer
BLYNK_WRITE(V0)
int tempLevel = param.asInt();
EEPROM.write(1, tempLevel);
setLevel(tempLevel);
Blynk.virtualWrite(V1, tempLevel);
/* Uppdatera nivå mot mobil för säkerhets skull?
BLYNK_CONNECTED()
Blynk.virtualWrite(V1, EEPROM.read(1));
// Kör periodiskt
void timerHit()
// Kolla om en period gĂĄtt, om inte, hoppa ur
periodicCount = periodicCount + 1;
if (periodicCount < period)
return;
Serial.println("Kör periodisk funktion");
// Eftersom en period gått, nolla räknaren
periodicCount = 0;
// Uppdatera, kanske hjälper
//Blynk.virtualWrite(V1, EEPROM.read(1));
// Börja om ifall räknarna blivit stora
if ( (connected > 65000) || (not_connected > 65000) )
connected = 0;
not_connected = 0;
// Kolla om grejerna är uppe
if (Blynk.connected() == true)
connected = connected + 1;
not_connected = not_connected + 1;
// Undvik nolldivision samt uppdatera procentandel
if ( (connected+not_connected) != 0 )
Blynk.virtualWrite(V5, 100*connected/(connected+not_connected));
Serial.print("Connected, not connected och andel:");
Serial.println(connected);
Serial.println(not_connected);
Serial.println(100*connected/(connected+not_connected));
// Temperaturer, kör tre mätningar per sensor
double tempHall = calcTemperature(analogRead(0),analogRead(0),analogRead(0));
double tempVardagsrum = calcTemperature(analogRead(1),analogRead(1),analogRead(1));
double tempUte = calcTemperature(analogRead(2),analogRead(2),analogRead(2));
double averageTempIn = (tempHall+tempVardagsrum)/2;
// Uppdatera temperaturer till mobil
Serial.println("Uppdatera temperaturer mot server");
Serial.println(tempHall);
Serial.println(tempVardagsrum);
Serial.println(tempUte);
Blynk.virtualWrite(V2, tempHall);
Blynk.virtualWrite(V4, tempVardagsrum);
Blynk.virtualWrite(V3, tempUte);
Blynk.virtualWrite(V6, averageTempIn);
/* Om senaste och förra mätningen är för låga -> stäng av
if ( (lastInhouse < 10) && (averageTempIn < 10) )
EEPROM.write(1,4);
setLevel(4);
lastInhouse = averageTempIn;
void timerHitLed()
digitalWrite(5, HIGH);
delay(40);
digitalWrite(5, LOW);
//Serial.println("Kör periodisk LED-funktion");
pinMode(2, OUTPUT); // Relä för level 3
pinMode(3, OUTPUT); // Relä för level 2
pinMode(4, OUTPUT); // Relä för level 1
pinMode(5, OUTPUT); // LED
// Använd inte SD-kort
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH);
// Vänta lite, öka chansen att routern vaknat efter strömavbrott
delay(1000*START_DELAY);
// Authentisera mot cloud
Blynk.begin(auth);
// Om det är första gången, sätt level
if (EEPROM.read(0) != 173)
EEPROM.write(0,173);
EEPROM.write(1,4);
setLevel(4);
// Sätt sparat värde
setLevel(EEPROM.read(1));
// Periodisk funktion, kör varje minut för att pusha data
periodicTimer.setInterval(60000L, timerHit);
ledTimer.setInterval(5000L, timerHitLed);
periodicTimer.run();
ledTimer.run();
// Gör om mätvärde till temperatur
double calcTemperature(int reading1, int reading2, int reading3)
// Medelvärde
int reading = (reading1+reading2+reading3)/3;
double Temp;
Temp = log(10000.0 * ((1024.0 / reading - 1)));
Temp = 1 /(0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp)) * Temp);
Temp = Temp - 273.15; // convert from Kelvin to Celsius
return Temp;
void setLevel(byte value)
// Sätt relä direkt
if (value==4)
digitalWrite(2,LOW);
digitalWrite(3,LOW);
digitalWrite(4,LOW);
if (value==3)
digitalWrite(2,HIGH);
if (value==2)
digitalWrite(3,HIGH);
if (value==1)
digitalWrite(4,HIGH);
