started giving false results for some spesific pins. Seems to copy value from V11 to V12 and V13 (in my project)
No change in software or hardware for several weeks.
I have pins V11, V21 and V31 in my project. Correct value for V11 is (at the moment) 4.000 (degrees). Using API calls I get the same value (4.000) for all these pins (V11, V21, V31). If the value for V11 changes (eg. 3.900), the same value copies to V21 and V31. This happens only in direct calls to pins.
If check these pins from App, they are correct, eg. 4.000, 23.000 and 20.800.
