Blynk API REST question
Hi
I’m building a soil moisture based on REST but I have some problem to upload data.
Code seems ok
The first shoot upload all OK
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cxxxx/update/V5?value=27.00
Float request respond : 200
Lux Level : 27
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cxxxx/update/V0?value=45.24
Humidity : 45.24%
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cxxxx/update/V1?value=24.88
Temparature: 24.88°C
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cxxxx/update/V2?value=20.00
Problems starts at second upload:
‘’‘http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cxxxx/update/V5?value=28.00
[sendFloatToBlynk] http connection failed
Float request respond : -1
Lux Level : 28
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cxxxx/update/V0?value=45.28
Humidity : 45.28%
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cxxxx/update/V1?value=24.89
and so on…
there is some flooding protection? or limits?
For sure, it’s basically a free service and it wouldn’t be able to handle trillions of transactions would it.
If you need high data throughput Blynk have dedicated servers for you with their subscription service.
How frequently are you trying to upload?
@Costas actually, there is no limits for HTTP API right now :wink:.
@joepesce in text you paste I see
Doesn’t that mean that request was successfully processed?
Yes but presumably the -1 on the second run means fail?
hi thank you for all your answers
sensors is on ESP32
turn on from deepsleep, read 4-5 values, uploads and turn off
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cXXXX/update/V5?value=35.00
Lux Level : 35
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cXXXX/update/V0?value=46.47
Humidity : 46.47%
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cXXXX/update/V1?value=23.77
Temparature: 23.77°C
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cXXXX/update/V2?value=0.00
Moisure lvl: 0
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cXXXX/update/V3?value=48
int request respond : -1
WiFi RSSI: 48%
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cXXXX/update/V4?value=0
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cXXXX/update/V4?color=%23D3435C
property request respond : -1
[sendFloatToBlynk] http POST failed
notification request respond : -1
start:
http://blynk-cloud.com:8080/b6e8ebe68b6d483cb0506e545b8cXXXX/notify
“to”:"xxxxxxxxxxxx@gmail.com",
“title”:“Plant”,
“subj”:“Battery drained…”
81
Battery Lvl: 0%
[get_OTAStatus] http connection failed
it works only at first connection after 10-15 minutes… but if I want to wake up every 3min or 5min (for example) it give me the error that I post
Seems like issue with your code. Please paste it.
int sendEmailToBlynk(String email, String subject, String message){
  HTTPClient http;
  int returnValue = -1;
  /* prepare the json messsage */
  String jsonPayload = String("{\n\"to\":\"") + email + String("\",\n") +
                       String("\"title\":\"") + subject + String("\",\n") +
                       String("\"subj\":\"") + message + String("\"\n}");
  /* prepare the REST request */
  String POST_STING = "http://" + String(blynk_server)+ ":" + String(blynk_port) + "/" + String(auth) + String("/notify");
  #ifdef DEBUG
  #ifdef NETWORK_DEBUG
  Serial.println("\nstart:");
  Serial.print("\t");
  Serial.println(POST_STING);
  Serial.println("\t*****************");
  Serial.print("\t");
  Serial.println(jsonPayload.c_str());
  Serial.print("\t");
  Serial.println(jsonPayload.length());
  #endif
  #endif
  /* start blynk http connection */
  http.begin(POST_STING);
  http.addHeader("Content-Type", "application/json");
  int httpCode = http.POST((uint8_t*) jsonPayload.c_str(), jsonPayload.length());      // send post request
  if( httpCode > 0){
    returnValue = 0;
    #ifdef DEBUG
    Serial.print("email request respond : ");
    Serial.println(httpCode);
    Serial.print("server reply : ");
    Serial.println(http.writeToStream(&Serial));
    #endif
    #endif
  }else{
    returnValue = -2;
    #ifdef DEBUG
    Serial.println("[sendFloatToBlynk] http POST failed");
    #endif
  http.end();             //close the http
  return returnValue;
I edited your code formating… use backticks not commas, thanks.
Blynk - FTFC
thank you!
no one have an idea?
@joepesce seems strange, please confirm I have this correct. You send approx 5 updates via API to Blynk, deepSleep for 15 minutes and when you repeat all is fine. But if you reduce deepSleep to 3 or 4 minutes the first upload is OK but no subsequent uploads?
Doesn’t really make any sense, is there anything you are omitting to tell us or is that the full procedure?
if I don’t send any data (or try to send) in 10-15 min. Just turn on or off esp32 it goes OK
if I try to send data it’s ok only first time and after it is like server block me and I have to stop to try send data for a period
I notice you are using the email widget in the API. @Dmitriy I know you said their were “no limits” with the API but surely you are not allowing a trillion emails a day from @joepesce to go through the server?
@joepesce disable email part and retest.
is only in the code, the app don’t have widget. I don’t know if it’s the same
In your code above you have:
int sendEmailToBlynk(String email, String subject, String message){}
Try with this function disabled and let us know the results. Either you are blocked for spamming or blocked for using a widget that is not in the your app. Note: Gmail allow 100 emails per day so you will be locked out by somebody if you try every few minutes.
it seems works now :slight_smile:
thank you so much
