Blynk and Arduino Yun (wifi): Slow Response
Hello.
I am using the Blynk app (on iPhone) to control an Arduino Yun board over wireless.
When I run a simple example from the Blynk library (the Arduino Yun example), the app/board work(s) fine.
However, when I add the app setup to my main code, I get about a minute delay from the time I change a controller on the app to the time I get a response on the board.
My code uses temperature and humidity sensors to control LEDs on the board, which are also controlled by using the Blynk app (to turn the same LEDs on and off).
My question is: is there a way to minimize the delay?
Thank you.
Where are you located?
You should try installing Blynk Local Server and see if it works:
docs.blynk.cc/#blynk-server
