Blynk and Android device
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
Edit your post (using the pencil icon at the bottom) and explain what your problem is. Read the info that’s in your current post to understand what type of data you need to include in your post.
