@MDurie Add widgets switch (V0 set to pulse) and led (V1) on your app then use this test code:
import BlynkLib
import BlynkTimer
import socket, errno
import RPi.GPIO as GPIO
from datetime import datetime as dt
#set GPIO pinout
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
#set physical relay pins as output
rel_S1 = 5 #pin 29 CH1 V0
#leds status as input
in_ledS = 17 #pin 11
arr_relays = [rel_S1]
#setup pins as output
GPIO.setup(arr_relays, GPIO.OUT)
arr_leds = [in_ledS]
#setup pins as input
GPIO.setup(arr_leds, GPIO.IN)
#cloud server
BLYNK_TEMPLATE_ID = ''
BLYNK_DEVICE_NAME = ''
BLYNK_AUTH = ''
blynk = BlynkLib.Blynk(BLYNK_AUTH)
# Create BlynkTimer Instance
timer = BlynkTimer.BlynkTimer()
def init():
#set putput state of relay pins
GPIO.output(arr_relays, GPIO.HIGH)
GPIO.cleanup(arr_relays)
def update_virtual_led():
#S
if(GPIO.input(arr_leds[0]) == 1):
blynk.virtual_write(1, 0)
else:
blynk.virtual_write(1, 255)
@blynk.on('V0')
def S1_write_handler(value):
if int(value[0]) == 1:
print('relay on')
GPIO.setup(arr_relays[0], GPIO.OUT)
GPIO.output(arr_relays[0], GPIO.LOW)
timer.set_timeout(1, S1_timeout)
#--- timeouts ---
def S1_timeout():
GPIO.output(arr_relays[0], GPIO.HIGH)
GPIO.cleanup(arr_relays[0])
print('relay off')
@blynk.on("connected")
def blynk_connected():
print('Updating leds values from the server...')
blynk.sync_virtual(1)
#--- activate timers ---
timer.set_interval(2, update_virtual_led) #update virtual leds for 2 secs
if __name__ == "__main__":
init() #runs once
while True:
try:
blynk.run()
timer.run()
except socket.error as e:
print(e)
if(e.errno != errno.EPIPE):
t = time.time()
s = dt.fromtimestamp(t).strftime('%d/%m/%Y %H:%M:%S - ')
logging.error(s + "err blynkmain " + str(e))
raise
blynk.connect()
