Hello
I am currently running Blynk 1.0 with custom server and want to go to 2.0. I have searched but cant seem to find a clear answer on wether or not my sketch will continue to run if internet connection is down. I am going to be running an A/C unit with a particle Photon to control cooler temp. If internet goes down or connection lost will the Photon know or retain the set temp on the slider widget? I did read on the forum somewhere 2.0 would be able to accomplish this in the future, post was about 1yr old. Has this been accomplished and if so how or what do i need to do? Below is the sketch
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Ethernet board
example.
#include <blynk.h>
//#include "math.h"
//#include "adafruit-sht31.h"
// Temp/Humidity Sensor
//Adafruit_SHT31 sht31 = Adafruit_SHT31();
#include <Wire.h>
#include "DFRobot_SHT20.h"
DFRobot_SHT20 sht20;
SYSTEM_THREAD(ENABLED);
char auth[] = "xxxxxxxxxxxxxxxxx";
const char* IP = "xxxxxxxxxxxxxx";
bool tempflag = true;
int relaisOn = D7;
int relaisV = D6;
int hysteresis = 2;
float Thermostat = 0;
//float h = sht20.readHumidity(); // Read Humidity
//float t = sht20.readTemperature();
//float Thermostat = (t* 9) /5 + 32;
BLYNK_WRITE(V4) {
Thermostat = param.asFloat();
// the timer object
//Serial.println("SHT20 Example!");
sht20.initSHT20(); // Init SHT20 Sensor
delay(100);
sht20.checkSHT20();
Blynk.config(auth, IP, 80);
delay (5000);
timer.setInterval(7 * 1000L, sendSensor) ;
timer.setInterval(1000L, relaisAlim);
//timer.setInterval(30 * 1000L, Temp) ;
//timer.setInterval(5 * 1000L, sendTemps) ;
//timer.setInterval(5000L, TempNotify );
void sendSensor()
float ftemp = (t* 9) /5 + 32;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, ftemp);
//Serial.print(" Temperature:");
//Serial.print(ftemp, 1);
//Serial.print("F");
//Serial.print(" Humidity:");
//Serial.print(h, 1);
//Serial.print("%");
void relaisAlim()
//Serial.print("Temperature : ");
// Serial.print(TempSom);
//Serial.println("°C");
//Serial.print("Thermostat : ");
//Serial.println(Thermostat);
if (ftemp >= (Thermostat + hysteresis))
digitalWrite(relaisOn, 1);
Blynk.virtualWrite(V3, 0);
Blynk.virtualWrite(V2, 255);
else if (ftemp <= (Thermostat - hysteresis))
digitalWrite(relaisOn, 0);
Blynk.virtualWrite(V2, 0);
Blynk.virtualWrite(V3, 255);
