Dear Blynk Team
i using Blynk legency more then 1 year ago i have no issue now i am going to shift blynk 2.0
i have 2 esp32 1is using blynk legency and another 1is using blynk 2.0 in Blynk 2.0 i found that when my router restart Blynk 2.0 esp32 not connecting again to the network i have to go and manual reset esp32 then it will connect to my router and another esp32 using with blynk legency that is no issue it will auto connect
can anyone have the solution for this or may be i need to use Reset function after my blynk disconnected from the router then it will auto reset every 1minute until the wifi is connected to the ESP32
can you please provide me example code how to write code for reset function
thank for reply sir
i am not sure sir previous what i exactly make changes on those pins yes but i just remeber i will make changes ther because of some reason
thanks for helping sir now is working well
