Dear Blynk Team
I have issue on Blynk 2.0 LCD display text not stable when I close and open again the Blynk2.0 application Blynk display no more showing,
I use Blynk legency no issue ever everything is working fine in Blynk legency,
I attached here the code video I can’t share because not supported
I hope you hear me soon
Best Regards
Maaz
char ssid[] = "Testing 2.0";
char pass[] = "gfgggfvvvc";
WidgetLCD lcd(V4);
BLYNK_WRITE(V5)
if ( param.asInt () == 1)
digitalWrite(17,LOW);
lcd.clear();
digitalWrite(17,HIGH);
lcd.print (4,1,"SELECT OPEN");
BLYNK_WRITE(V2)
digitalWrite(21,LOW);
lcd.clear();
digitalWrite(21,HIGH);
lcd.print (4,1,"SELECT AUTO");
BLYNK_WRITE(V0)
digitalWrite(18,LOW);
lcd.clear();
digitalWrite(18,HIGH);
lcd.print (4,1,"SELECT LOCK");
BLYNK_WRITE(V1)
digitalWrite(23,LOW);
lcd.clear();
digitalWrite(23,HIGH);
lcd.print (4,1,"SELECT EXIT");
pinMode (18,OUTPUT);
pinMode (19,OUTPUT);
pinMode (21,OUTPUT);
pinMode (17,OUTPUT);
