Blynk 2.0. Blynk.app and Blynk.360 web dashboard
Diving into V2.0. Starting simple
Quick question.
On template dashboard I have a switch linked to datastream V0.
On blynk.app I have button linked to V0.
Device is correct. I can see it’s online on the web device dashboard. The button operates the onboard led and that’s responding as expected using the button on the app.
If I click on the button on the app should I see the state change on the switch on the web dashboard?
If I change the switch on the dashboard should I see the button change of state on the app?
If so then it’s not happening. Suggestions?
Ah. Solved. I was using the web dashboard under the template screen.
I should have been in the devices section on blynk.360 looking at the dashboard.
