Bluetooth HC-06 - can't get any of the Display widgets working
Hello, can someone confirm that with the latest local server & Arduino Blynk library using an HC-06 Bluetooth adapter the Display widget works? I tried polling & push but no luck. I can get other widgets working (slider, button) so I know that communication is working.
Thank you kindly!!
Hello. Android?
Yes
