Hi
I have a MPU5060 and a HC-06 bluetooth module connected to an arduino nano which i’m using to communicate with the Blynk app.
The app connects nicely to the arduino via bluetooth and as a test I am writing the millis to the v5 pin and displaying that on the app. I am also displaying a stream of gyro data on the serial monitor.
My issue comes in with the fact that the application freezes from time to time for random intervals, anything from a second or two to 20 seconds. I have done a bit of research and it seems that the MPU code i’m using uses interrupts which doesn’t play nicely with SoftwareSerial.
As I understand there are two solutions, one being to change the MPU code to work without interrupts. The other is to connect the HC-05 to the hardware serial interface. I would like to go with this later solution. The demo version of the HC-05 code on the Bynk site requires SoftwareSerial however. Is there a way for me to connect the bluetooth module to Blynk using the hardware serial TX and RX pins on my arduino?
Please see my code below as reference.
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for SparkFun breakout and InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 mpu;
//MPU6050 mpu(0x69); // <-- use for AD0 high
// uncomment "OUTPUT_READABLE_YAWPITCHROLL" if you want to see the yaw/
// pitch/roll angles (in degrees) calculated from the quaternions coming
// from the FIFO. Note this also requires gravity vector calculations.
// Also note that yaw/pitch/roll angles suffer from gimbal lock (for
// more info, see: http://en.wikipedia.org/wiki/Gimbal_lock)
#define OUTPUT_READABLE_YAWPITCHROLL
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float euler[3]; // [psi, theta, phi] Euler angle container
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
//Calibration
float RollCalibrationReading; // initial roll reading before calibration, this value is used for calibrtion
float RollValue; // Roll angle
float CallibrationAdjustment; // Calibration adjustment
boolean RunCalibration = false; // has calibration run yet
// Handstand
boolean standStatus;
// timing
unsigned long startMillis;
unsigned long currentMillis;
unsigned long strandStartTime;
unsigned long standDuration;
// packet structure for InvenSense teapot demo
uint8_t teapotPacket[14] = { '$', 0x02, 0, 0, 0, 0, 0, 0, 0, 0, 0x00, 0x00, '\r', '\n' };
// === INTERRUPT DETECTION ROUTINE ===
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
mpuInterrupt = true;
// === BLUETOOTH SETUP ===
//SoftwareSerial SwSerial(7, 8); // RX, TX
//#include <SoftwareSerial.h>
char auth[] = "8e9354f3c75148acb8eb2efb56e221c7";
SoftwareSerial SerialBLE(7, 8); // RX, TX
// === INITIAL SETUP ===
// bluetooth
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
Serial.println("Connected");
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
Serial.println("Start testing LED");
// bluetooth
startMillis = millis();
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
// initialize serial communication
// (115200 chosen because it is required for Teapot Demo output, but it's
// really up to you depending on your project)
while (!Serial); // wait for Leonardo enumeration, others continue immediately
// NOTE: 8MHz or slower host processors, like the Teensy @ 3.3v or Ardunio
// Pro Mini running at 3.3v, cannot handle this baud rate reliably due to
// the baud timing being too misaligned with processor ticks. You must use
// 38400 or slower in these cases, or use some kind of external separate
// crystal solution for the UART timer.
// initialize device
mpu.initialize();
devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
mpu.setXGyroOffset(138);
mpu.setYGyroOffset(-37);
mpu.setZGyroOffset(41);
mpu.setZAccelOffset(1338); // 1688 factory default for my test chip
// make sure it worked (returns 0 if so)
// turn on the DMP, now that it's ready
mpu.setDMPEnabled(true);
// enable Arduino interrupt detection
attachInterrupt(0, dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
// set our DMP Ready flag so the main loop() function knows it's okay to use it
dmpReady = true;
// get expected DMP packet size for later comparison
packetSize = mpu.dmpGetFIFOPacketSize();
// === MAIN PROGRAM LOOP ===
currentMillis = millis();
// if programming failed, don't try to do anything
if (!dmpReady) return;
// wait for MPU interrupt or extra packet(s) available
while (!mpuInterrupt) {
// other program behavior stuff here
// if you are really paranoid you can frequently test in between other
// stuff to see if mpuInterrupt is true, and if so, "break;" from the
// while() loop to immediately process the MPU data
// reset interrupt flag and get INT_STATUS byte
// get current FIFO count
fifoCount = mpu.getFIFOCount();
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
} else if (mpuIntStatus & 0x02) {
// wait for correct available data length, should be a VERY short wait
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
// (this lets us immediately read more without waiting for an interrupt)
fifoCount -= packetSize;
// display Euler angles in degrees
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
RollValue = (ypr[2] * 180 / M_PI);
if ((RunCalibration == false) && (currentMillis - startMillis >= 2000)) //optimum millis 5000
Calibration();
else if (RunCalibration == true) {
TestMeasurements();
//MeasureHandstand();
// === CALIBRATION FUNCTION ===
void Calibration()
//Calibration reading
RollCalibrationReading = (ypr[2] * 180 / M_PI);
if ((RollCalibrationReading >= 0)&&(RollCalibrationReading <= 180)){
CallibrationAdjustment = RollCalibrationReading;
else if ((RollCalibrationReading > 180)&&(RollCalibrationReading <= 360)){
CallibrationAdjustment = RollCalibrationReading - 360;
//Take calibration reading once
Serial.print("Calibdarion value");
Serial.println(CallibrationAdjustment);
Serial.print("Time");
Serial.println(currentMillis);
Serial.println("");
RunCalibration = true;
// === TEST MEAUSREMENTS ===
void TestMeasurements() {
//Serial.print("rool value before calibration\t");
//Serial.println(ypr[2] * 180 / M_PI);
//Serial.print("roll angle after calibration\t");
Serial.println(RollValue);
Blynk.virtualWrite(V5, millis()/1000);
//Serial.print("\t");
//Serial.println(currentMillis);
// === HANDSTAND MEASUREMENT ===
void MeasureHandstand()
if (((RollValue > (100 + CallibrationAdjustment)) && (RollValue < (200 + CallibrationAdjustment))) && (standStatus == false)) {
// Doing handstand
Serial.println("upside down");
standStatus = true;
//start timer
strandStartTime = currentMillis - startMillis;
else if (((RollValue < (20 + CallibrationAdjustment)) || (RollValue > (300 + CallibrationAdjustment))) && (standStatus == true)) {
// Not doing handstand
Serial.print("right way up");
standStatus = false;
//end timer && display results - also save results to table under the date it was performed (table includes date, amount of handstands and their average time)
standDuration = currentMillis - strandStartTime;
Serial.print("\t Stand duration: ");
Serial.print(standDuration);
Serial.print(" milliseconds");
