Blinking Led
I think he wants someone to write his code :stuck_out_tongue_winking_eye:
This might work… well… the opposite way (Blinking LED when App disconnected)… I misinterpreted the OP question.
// Run if App disconnects
BLYNK_APP_DISCONNECTED() {
  // This dual nested timer routine will constantly blink the onboard LED of an ESP8266 Dev Board
  timer.setInterval(2000L, []() {  // Start 1st Timed Lambda Function - Turn ON LED every 2 seconds (repeating)
    timer.setTimeout(1000L, []() {  // Start 2nd Timed Lambda Function - Turn OFF LED 1 second later (once per loop)
      digitalWrite(2, HIGH); // Turn ESP On-Board LED OFF
    });  // END 2nd Timer Function
    digitalWrite(2, LOW); // Turn ESP On-Board LED ON
  });  // END 1st Timer Function
Perhaps try in the BLYNK_CONNECTED() function
Introduction - Blynk Documentation
Or use the same methods as reconnection routines and such with if() else() functions
  if (Blynk.connected()) {  // If connected run as normal
    LEDflashFlag == 1;
    LEDflashFlag == 0;
LEDflashFunc();
And then make a non-blocking LED flashing routine that only runs when the flag = 1
