I have an issue with the function “BlynkProvisioning.run ();” and my leds WS2812.
When I apply a fading effect some leds start to flash another color.
I think of a problem of interruption, do you have an idea?
#define USE_CUSTOM_BOARD // For all other ESP8266-based boards -
#define APP_DEBUG // Comment this out to disable debug prints
#define BLYNK_DEBUG
#define PIN_WS2812 5 // Set if your LED is WS2812 RGB
#define NBPIXELS 6 //nombre de pixels
#include <Adafruit_NeoPixel.h>
#include "BlynkProvisioning.h"
struct RGB {
byte r;
byte g;
byte b;
RGB LedColor = { 255 , 255 , 255 };
//quand isShowing = true, l'effet de "respiration" s'affiche
bool isShowing = false;
//moment à partir duquel on a lancé l'effet. Sert à savoir quand l'arrêter
uint32_t startTime = 0;
unsigned long breathe_time = millis();
//délai entre deux tours de boucle de l'animation "respiration". Plus la valeur est faible, plus la respiration est rapide
int breathe_delay = 10;
//durée de l'effet de respiration, en millisecondes
uint32_t duration = 13.1 * 1000L;
#define EFFECT_START_VALUE 100
int i = EFFECT_START_VALUE;
Adafruit_NeoPixel strip = Adafruit_NeoPixel( NBPIXELS, PIN_WS2812, NEO_GRB + NEO_KHZ800);
// Keep this flag not to re-sync on every reconnection
bool isFirstConnect = true;
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
BLYNK_WRITE(V0) {
LedColor.r = (byte)param[0].asInt();
LedColor.g = (byte)param[1].asInt();
LedColor.b = (byte)param[2].asInt();
isShowing = true;
DEBUG_PRINT("New color "+String(LedColor.r)+" "+String(LedColor.g)+" "+String(LedColor.b));
delay(500);
//initialisation des deux rubans de LED
strip.begin();
strip.Color(0, 0, 0);
strip.setBrightness(0);
strip.show();
BlynkProvisioning.begin();
// This handles the network and cloud connection
BlynkProvisioning.run();
Leaf();
void Leaf() {
//ce passage permet de lancer l'effet pour un certain temps.
//lorsque le temps est écoulé, on conserve la couleur avec la luminosité au max.
if (isShowing == true) {
if (startTime == 0) {
startTime = millis();
//on vérifie ici si le temps alloué est écoulé.
if ((millis() - startTime) < duration) {
LeafBreath();
startTime = 0;
isShowing = false;
//cette fonction gère l'effet de "respiration" en calculant, à partir d'une fonction à base sinusoïdale.
//Source: https://arduinoelectronics.wordpress.com/2015/05/12/non-blocking-breathing-led/
void LeafBreath() {
if ( (breathe_time + breathe_delay) < millis() ) {
float val = (exp(sin(i / 2000.0 * PI * 10)) - 0.36787944) * 108.0;
for (int n = 0; n < strip.numPixels(); n++) {
strip.setPixelColor(n, strip.Color(LedColor.r, LedColor.g, LedColor.b));
strip.setBrightness(val);
strip.show();
i++;
