BLESerial error in Blink Blynk example code
I am just trying to get started. I have an Arduino Pro Mini connected to a Bluefruit LE over SPI. I used the example code generator to create a Blynk Blink script. When I try to run it in Arduino IDE, it gives this error:
“No Matching function for call to BLESerial:BLESerial(int, int, int)”
I have installed the BLESerial library and all other required libraries.
Here is the full code:
@rsafipour please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
