Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
http://twitter.com/blynk_app
Blynk using a LED widget on your phone!
App project setup:
LED widget on V3
char auth[] = "e7fffa3d701e489cabf34582f3748126";
char ssid[] = "959e1a";
char pass[] = "280836872";
// Select your pin with physical button
const int btnPin = 5;
WidgetLED led3(V3);
WidgetLED led4(V4);
// V3 LED Widget represents the physical button state
boolean btnState = false;
void buttonLedWidget()
// Read button
boolean isPressed = (digitalRead(btnPin) == LOW);
// If state has changed...
if (isPressed != btnState) {
if (isPressed) {
led3.on();
led4.off();
led3.off();
led4.on();
btnState = isPressed;
// Setup physical button pin (active low)
pinMode(btnPin, INPUT_PULLUP);
timer.setInterval(500L, buttonLedWidget);
