Back to Ultrasonics
Hi I’m relatively new at this and I need some help. I want to set an Arduino Uno to signal through my wifi that the garage door is open. I’ve got this serial printing but when I add the code to enable pins 1 and 2 to light LED’s via Blynk I get coding errors. I’m sure it’s an ID10T error but help please.
Here’s the code.
http://1drv.ms/1WCfN3i
Thanks in advance
also how can I make serial monitor print to Blynk
Jim
Please follow instructions in sketch.
 * For this example you need Adafruit_CC3000_Library library:
         *   https://github.com/adafruit/Adafruit_CC3000_Library
         * Note: Firmware version 1.14 or later is preferred.
I thought I had included that but I’ll check thanks also how can I read the serial monitor in Blynk. As far as I can tell upgrading the cc3000 is easier said than done.
@JimSVMI83 look up the soft serial sketches for debug in serial monitor with Uno’s and Nano’s.
