• Hardware model + communication type: ESP32
• Smartphone OS (iOS or Android) + version: iOS 15.5
• Blynk server or local server: Blynk server
• Blynk Library version: 1.1.0
I have created 2 similar double virtual pin Datastreams, the only difference being the name. Both are setup as automation type “Sensor” with Condition switched on in the Automation tab.
Only the first variable shows all possible conditionals: is greater than, is less than, etc. The second variable only shows: is on, is off, has changed, is any. I have played around with various settings in Datastreams and Automations to no luck.
How do I get the 2nd variable to allow for more conditionals?
