Automatic disconnection
I wanted to switch off the out put when blynk is disconnected from net, can somebody help me.
Please start by providing the requested information…
  1. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
```cpp
and stating whether you are using the old version of Blynk,. or the newly released Blynk.360 & Blynk.Edgent product.
Also, please provide more information about what exactly you are trying to achieve.
