Automatic Control and User Interface for Central Tire Inflation System
@Eyberg the last line suggests the compilation was fine. Just need to write the code to your Arduino now.
@Costas Thanks, nice I try it, so this should work? :slight_smile:
@Eyberg there might be a few bits and bobs to iron out but if you provide details from Serial Monitor we can probably iron them out.
You should also post details of what the timing frequencies are. Ideally they should be at least a few 100ms.
Is not forgotten this :slight_smile:
I am waiting for components for this project because I’m trying to set this up as orginal and connect with Blynk.
While I read all about Blynk and what you are doing here :slight_smile:
how can i see Digital pins for lcd in virtual pins?
this is what controls the Digits pins to run in the LCD?
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
Has been looking at this and read a lot not realizing how I can put this into the code that I have :slight_smile:
What kind of display do you want, a virtual one the app or an actual physical one? Because the physical one has nothing to do with virtual pins. That just works with the library as it is.
I would like to use a virtual one Blynk lcd to see what’s happening.
Orginal code use this display
Virtual is the new buzz word and will be a major part of all our futures. Why pay top dollar for something when the virtual equivalent is so much cheaper and easier to use. Wise move Sir.
In that case, if you plan on removing the physical one, you can throw out the LiquidCrystal library in total. If you still want to keep that, because I can imagine you want to glance at it while driving, you can just add the Blynk LCD widget and put it alongside everywhere where the physical one outputs information.
You can check the LCDWidget example. It works almost exactly the same as the physical one.
Has set up a W5100 Ethernet Shield for my Arduino and connect to the local server onl Raspberry PI3 and has been testa this and it works :slight_smile:
Now I’m going to place the code that I have in to Arduino and saw this!
NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
DON’T use them in your sketch directly!
What do I need to do this or does not matter
what does this mean?
[2694] IP:192.168.10.4
[2714]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.4.6 on Arduino 101
[5001] Connecting to blynk-cloud.com:8442
[10002] Connecting to blynk-cloud.com:8442
[15003] Connecting to blynk-cloud.com:8442
[20004] Connecting to blynk-cloud.com:8442
[25005] Connecting to blynk-cloud.com:8442
That means, that you forgot to change server’s address in sketch :slight_smile: (a client side - Arduino)
Using this code, I see Ip address in the router from Arduino, Tablet and the Raspberry Pi but can not connect to the local server on the Raspberry Pi!
Using W5100 Ethernet Shield connect to router and pi connect to router on wifi !
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Sketch generator:           http://examples.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * This example shows how to use Arduino Ethernet shield (W5100)
 * to connect your project to Blynk.
 * Feel free to apply it to any other example. It's simple!
 * NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
 *       DON'T use them in your sketch directly!
 * WARNING: If you have an SD card, you may need to disable it
 *       by setting pin 4 to HIGH. Read more here:
 *       https://www.arduino.cc/en/Main/ArduinoEthernetShield
#include <Ethernet.h>
char auth[] = "3295d2122335428a8a8877a04a64367b";
#define W5100_CS  10
#define SDCARD_CS 4
  pinMode(SDCARD_CS, OUTPUT);
  digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
  Blynk.begin(auth);
  // You can also specify server.
  // For more options, see Boards_Ethernet/Arduino_Ethernet_Manual example
  //Blynk.begin(auth, "192,168,10,3", 8442);
  //Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
This entry (the active one) doesn’t specify local server’s address, that is why it tries to connect to default cloud server.
You have to specify local server’s address, for example: Blynk.begin(auth, IPAddress(192,168,1,100));
I was testing everything except that you posted above :smile:
[2695] IP:192.168.10.5
[2715]
    ___  __          __
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.4.6 on Arduino 101
[5001] Connecting to 192.168.10.3
[5134] Ready (ping: 8ms).
Is this not að problem ?
these pins are SPI bus, which W5100 uses to communicate with uC (and vice-versa :slight_smile: ) You should avoid using them, unless you don’t want to mess with some troubles. If they are necessary in your project, try to change them to something else (some free analog pins?) If You still run out of pins you might consider using some I2C expander…
Ok thanks
I am not gonna use LiquidCrystal lcd(2, 3, 4, 5, 6, 7); I neat to get them in to Virtual pins and Blynk lcd.
It will be a challenge :sunglasses:
You will be surprised how easy it will be :smiley: Just read and try a lot of examples similar to your needs, and go on. Also do not confuse virtual pins (which you can treat just as a variable - sometime structured, sometime simple) with hardware pins, i.e GPIO of uC. good luck!
Hehehe :relaxed:
will try for a few days and come back, put all the code in to Arduino, and no error
Tanks for the help
Was registering for courses in Arduino 3 weeks
Arduino for beginners and advanced
