All my details, AUTH Token, Template ID are correct as per my dashboard but every time my WSP8266 connects to the blynk server it says Authentication Token invalid.
I read that it could be a GEO problem but where do you change the Blynk server details?
Or am I missing something?
Blynk IOT is definitely not as user friendly for beginner as Legacy was.
OH Duh! Thanks for that, hadnt seen that.
I was using the template from the Blynk example, you would think that it would have been coded correctly.
Thanks!
@otto please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
