Auth toke invalid
[11834] Connected to WiFi
[11834] IP: 192.168.109.227
[11834]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.5.8 on Arduino
[11841] Connecting to blynk-cloud.com:80
[12033] Invalid auth token
this is my code
  This example shows how value can be pushed from Arduino to
  the Blynk App.
  WARNING :
  For this example you'll need Adafruit DHT sensor libraries:
    https://github.com/adafruit/Adafruit_Sensor
    https://github.com/adafruit/DHT-sensor-library
  App project setup:
    Value Display widget attached to V5
    Value Display widget attached to V6
#define BLYNK_TEMPLATE_ID "TMPL4Cvekawb"
#define BLYNK_DEVICE_NAME "Water Quality"
#define BLYNK_AUTH_TOKEN "V9bTsvdXRzmSSQ4BfYVhC_nEN3N4ZMAA"
#include <OneWire.h>
char ssid[] = "";
char pass[] = "";
#define ONE_WIRE_BUS 2
DallasTemperature DS18B20(&oneWire);
const int analogpin = A0;
float temp;
float volt;
   DS18B20.begin();
  timer.setInterval(5000L, getSendData);
void getSendData()
  float turbidity = analogRead(A0);
  float volt = turbidity*(5.0/1024);
  DS18B20.requestTemperatures();
  temp = DS18B20.getTempCByIndex(0); // Celcius
  Serial.print(temp);
  Serial.print(" \xC2\xB0"); // shows degree symbol
  Serial.print("C  |  ");
  Serial.print("Turbidity: ");
  Serial.println(volt);
  Blynk.virtualWrite(V0, volt);
  Blynk.virtualWrite(V3, temp); //virtual pin V3
You should update the library to the latest version (1.1.0).
If you have Blynk for Chinese installed as well as Blynk 1.1.0 then you need to un-install Blynk for Chinese.
