Greetings!
TLDR: Infinite loop of the following messages while running the python program:
Connected to blynk server
Authenticating device…
Auth stage timeout
Note: the authentication key is changed to the correct one when switching from blynk to a local server
Code that works;
blynk = blynklib.Blynk(BLYNK_AUTH)
Note: using the correct ip and port locally (the one that is used for the admin panel)
Code attempted to change;
blynk = blynklib.Blynk(BLYNK_AUTH, server=‘192.168.x.x’, port=8443, log=print )
Library used: GitHub - blynkkk/lib-python: Blynk IoT library for Python and Micropython
Inspected the error message with no avail here: https://github.com/blynkkk/lib-python/blob/master/blynklib.py
I am using a Raspberry Pi 3B+, that is running a local server, which has been successfully logged into from the android application. In addition, I’ve already ran a working program and blynk project on the raspberry pi. What I am now attempting to change is the way the python program connects to a specific blynk server.
Any pointers are appreciated.
Thanks in advance,
