First, thanks so much for your hard work. I was wondering if text could be controlled when sending data to the terminal. Having the text change colors would be great for getting attention. Thanks.
I haven’t tested it with Terminal myself, but you can try http://docs.blynk.cc/#blynk-main-operations-change-widget-properties Although I think that will only switch between the background colours as text is only white or black on Terminal.
All other applicable Widgets can have the whole gambit of colours for the text.
