It would be great to have widget arrays. For example, array of indicators. Suppose I have a bunch of themp sensors attached to my arduino, but the number is flexible (the sensors can be added and removed from bus). I could send their names/temperatures as array, and the “array-widget” could display them as 'subwidgets", filling a designated area of presenting a scrollable pane.
Interesting. Saved to pool of ideas
I have similar needs in that I built an 8 head dosing unit, have code to calibrate and run it via Blynk, but now want to add indicating LED widgets for each of the 8 pumps. Everything else in the function is fitted into arrays and indexed accordingly, now just need to also index the LEDs (if possible).
Needless to say, BUMP!
Edit - My issue was resolved HERE. Just wanted to link that post to this for future researchers on this topic.
I think this original idea has since been realised by the Table Widget - http://docs.blynk.cc/#widgets-interface-table
Or are you looking for a LED matrix type widget?.. which is more for simple graphics. Or something else?.. if so I recommend a new Idea Topic (or GitHub request) so as not to be confused with the older ones.
