Hello!
I am trying to do a project of an armbot that gets the positions of 5 servos from the user, stores on 5 arrays and after uses to repeat a sequence. For that I’m just using a Nano version of Arduino and 5 servos. The fact is that after I get the position points for the sequence I try to execute and it cannot do each step… I’ve already try to put a delay after any of the movements but then I get an error…I’m just a newbie and I’ve tried to google any solution without any success so my alternatives just gone away… Here is my code (the sequence is executed when press V8 button / comments and terminal writes are in portuguese but they are not important):
//Define comunicação serial do Blynk com o USB
#define BLYNK_PRINT SwSerial
SoftwareSerial SwSerial(2, 3); // RX, TX
//Inclui biblioteca do servo
#include <Servo.h>
// Token de autenticação do Blynk (para cada projeto)
char auth[] = "cb6b4e5873e149a48e32fd774a6efaec";
// Definição dos nomes dos servos
Servo garra;
Servo pulso;
Servo cotovelo;
Servo ombro;
Servo tronco;
// Configurando terminal
WidgetTerminal terminal(V0);
// Definição das variáveis de posição dos servos e das auxiliares para sequência
int garraPOS[10];
int garraINST;
int pulsoPOS[10];
int pulsoINST;
int cotoveloPOS[10];
int cotoveloINST;
int ombroPOS[10];
int ombroINST;
int troncoPOS[10];
int troncoINST;
int i;
int j;
// Movimentação dos servos pelos sliders
BLYNK_WRITE(V1)
garra.write(param.asInt());
if (garraINST != param.asInt()){
garraINST = param.asInt();
BLYNK_WRITE(V2)
pulso.write(param.asInt());
if (pulsoINST != param.asInt()){
pulsoINST = param.asInt();
BLYNK_WRITE(V3)
cotovelo.write(param.asInt());
if (cotoveloINST != param.asInt()){
cotoveloINST = param.asInt();
BLYNK_WRITE(V4)
ombro.write(param.asInt());
if (ombroINST != param.asInt()){
ombroINST = param.asInt();
BLYNK_WRITE(V5)
tronco.write(param.asInt());
if (troncoINST != param.asInt()){
troncoINST = param.asInt();
// Gravar pontos
BLYNK_WRITE(V6)
if (param.asInt() == 1){
i = j;
garraPOS[i] = garraINST;
pulsoPOS[i] = pulsoINST;
cotoveloPOS[i] = cotoveloINST;
ombroPOS[i] = ombroINST;
troncoPOS[i] = troncoINST;
terminal.flush();
Blynk.virtualWrite(V0,"* Gravado ponto: ");
Blynk.virtualWrite(V0,i);
i++;
j++;
// Limpar pontos
BLYNK_WRITE(V7)
terminal.flush();
Blynk.virtualWrite(V0,"*** Limpando pontos.");
for (i=0; i <= j; i++){
garraPOS[i] = 0;
pulsoPOS[i] = 0;
cotoveloPOS[i] = 0;
ombroPOS[i] = 0;
troncoPOS[i] = 0;
i = 0;
j = 0;
// Realizar sequência
BLYNK_WRITE(V8)
terminal.flush();
Blynk.virtualWrite(V0,"Iniciada sequência de posições. ");
Blynk.virtualWrite(V0,"Total de ");
Blynk.virtualWrite(V0," pontos para executar.");
for(i=0; i<= j; i++){
garra.write(garraPOS[i]);
pulso.write(pulsoPOS[i]);
cotovelo.write(cotoveloPOS[i]);
ombro.write(ombroPOS[i]);
tronco.write(troncoPOS[i]);
Blynk.virtualWrite(V0,"** Ponto: ");
i = j;
SwSerial.begin(9600);
// Blynk funcionará pelo serial, deve-se abrir no Arduino IDE: Ferramentas -> Blynk:Run USB Script
Blynk.begin(Serial, auth);
// Define os pinos para os servomotores
garra.attach(5);
pulso.attach(6);
cotovelo.attach(9);
ombro.attach(10);
tronco.attach(11);
// Calibração de posição incial dos servomotores e limpando variáveis
for (0; i <= j; i++){
garraPOS[i] = 0;
pulsoPOS[i] = 0;
cotoveloPOS[i] = 0;
ombroPOS[i] = 0;
troncoPOS[i] = 0;
i = 0;
j = 0;
// garra.write(70);
// pulso.write(90);
// cotovelo.write(130);
terminal.clear();
terminal.flush();
Blynk.virtualWrite(V0,"Olá! Calibração concluída e servos em posição inicial.\n");
