Are the Blynk cloud servers down
Since yesterday (March 25 2016) I have been unable to login or create new accounts via the iOS app. This morning I was unable to login to the forums.
Are the cloud servers having problems?
thanks!
donour
Forum and Blynk cloud are totally different things. However everything is up and running.
Thanks Pavel. I figured as much, but wanted to check.
It looks like my account is in a weird state. If i try to create a new account, it fails because the email address has already been used. If i try to login or reset the password, “we don’t have such an email address”.
I just verified that I can create new accounts with other addresses, which I was unable to do last night – I tried from several networks.
Thanks for your hard work!
Same problem here. I think is the server software because I setup a “local” server, and I was having the same problem. I thought something was miss configured, but after some tries, I was able to create an account and log in. Ufffffff! Frustrating! :frowning: However, if I log out, I have the same problem: “we don’t have such an email address”. Local server and Blynk server report the same.
Same for me. I can only access the forum from one machine as it will not accept my username and password from a second machine.
I’m not getting into my esp8266. I don’t think it’s my code because I haven’t changed it since it was last working. Had to get Dimitri to add my account to a list after I wasn’t able to add widgets,(subscription service going online or something).
@ITAlex so problem with reset password on local server?
@donour could you please provide me with your account.
Yes, Dmitriy, I have the same problem in a local server: “we don’t have such an email address.” After some retries, it let me create an account and log in. If I log out, I get the same message. Once again, after some retries, I am able to log it.
By the way, you guys’ instructions how to install the local server are sooo easy. Its basically, 1, 2, 3, and bang! It works. Good job.
@ITAlex what version of server do you use?
Dmitriy :I used: server-0.14.1.jar, the machine is running Ubuntu latest version 15.04, 64 bits.
@ITAlex How do you try to access local server? From local network or from outside? What IP address do you use?
Dmitriy:
Its not a “local server” per se, is a cloud server provided by linode,com I access it from my home local network, I use a private IP address to access the public IP address where the server is located. No sure if I answered your question.
@ITAlex you may try to add below properties to server.properties
reset.pass.http.port=7444
reset-pass.http.host=YOUR_SERVER_IP
This properties required to enable reset-pass on local server. By default local server ip address is used. So this may be a problem in our case. Also check above port is open on your server.
@Dmitriy is there a way to send you a private message on the community forums? I would rather not post my email address in the clear. Is it the same as the email address for this account, if you can query that directly.
@donour you can send to dmitriy@blynk.cc
