Hello friends I am trying to program my arduino board one with shield sheiled v 2.0
used this example:
https://examples.blynk.cc/?board=Arduino%20Uno&shield=nRF8001&example=GettingStarted%2FBlynkBlink
and I receive this error:
Arduino:1.8.5 (Windows 10), Tarjeta:"Arduino/Genuino Uno"
C:\Users\Usuario\AppData\Local\Temp\arduino_modified_sketch_205613\nRF8001.ino:45:23: fatal error: BLESerial.h: No such file or directory
#include "BLESerial.h"
compilation terminated.
exit status 1
Error compilando para la tarjeta Arduino/Genuino Uno.
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
Looks like you’re missing some libraries! From the example sketch you’re using:
For this example you need BLEPeripheral library
from http://librarymanager/all#BLEPeripheral
or https://github.com/sandeepmistry/arduino-BLEPeripheral
30/5000
I have installed the libraries
That’s strange… Try reinstall it and restart the IDE?!
Enable “Show verbose output during compilation” for a more detailed error message.
Arduino: 1.8.5 (Windows 10), Card: "Arduino / Genuino Uno"
C: \ Program Files (x86) \ Arduino \ arduino-builder -dump-prefs -logger = machine-hardware C: \ Program Files (x86) \ Arduino \ hardware-hardware C: \ Users \ User \ AppData \ Local \ Arduino15 \ packages -tools C: \ Program Files (x86) \ Arduino \ tools-builder -tools C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -tools C: \ Users \ User \ AppData \ Local \ Arduino15 \ packages -built-in-libraries C: \ Program Files (x86) \ Arduino \ libraries -libraries C: \ Users \ Users \ Documents \ Arduino \ libraries -fqbn = arduino: avr: one -ide-version = 10805 -build -path C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_636113 -warnings = default -build-cache C: \ Users \ User \ AppData \ Local \ Temp \ arduino_cache_362834 -prefs = build.warn_data_percentage = 75 -prefs = runtime .tools.arduinoOTA.path = C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -prefs = runtime.tools.avrdude.path = C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -prefs = runtime.tools.avr-gcc.path = C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -verbose C: \ Users \ User \ AppData \ Local \ Te mp \ arduino_modified_sketch_866677 \ nRF8001.ino
C: \ Program Files (x86) \ Arduino \ arduino-builder -compile -logger = machine -hardware C: \ Program Files (x86) \ Arduino \ hardware-hardware C: \ Users \ User \ AppData \ Local \ Arduino15 \ packages -tools C: \ Program Files (x86) \ Arduino \ tools-builder -tools C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -tools C: \ Users \ Users \ AppData \ Local \ Arduino15 \ packages -built-in-libraries C: \ Program Files (x86) \ Arduino \ libraries -libraries C: \ Users \ User \ Documents \ Arduino \ libraries -fqbn = arduino: avr: one -ide-version = 10805 -build-path C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_636113 -warnings = default -build-cache C: \ Users \ User \ AppData \ Local \ Temp \ arduino_cache_362834 -prefs = build.warn_data_percentage = 75 -prefs = runtime.tools .arduinoOTA.path = C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -prefs = runtime.tools.avrdude.path = C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -prefs = runtime.tools.avr-gcc.path = C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -verbose C: \ Users \ User \ AppData \ Local \ Temp \ arduino_modified_sketch_866677 \ nRF8001.ino
Using board 'one' from platform in folder: C: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr
Using core 'arduino' from platform in folder: C: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr
Detecting libraries used ...
"C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr / bin / avr-g ++" -c -g -Os -w -std = gnu ++ 11 -fpermissive -fno-exceptions -ffunction-sections - fdata-sections -fno-threadsafe-statics -flto -w -x c ++ -E -CC -mmcu = atmega328p -DF_CPU = 16000000L -DARDUINO = 10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ cores \ arduino "" -IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ variants \ standard "" C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_636113 \ sketch \ nRF8001.ino.cpp "-o" nul "
"C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr / bin / avr-g ++" -c -g -Os -w -std = gnu ++ 11 -fpermissive -fno-exceptions -ffunction-sections - fdata-sections -fno-threadsafe-statics -flto -w -x c ++ -E -CC -mmcu = atmega328p -DF_CPU = 16000000L -DARDUINO = 10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ cores \ arduino "" -IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ variants \ standard "" -IC: \ Users \ User \ Documents \ Arduino \ libraries \ Blynk \ src "" C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_636113 \ sketch \ nRF8001.ino.cpp "-o" nul "
"C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr / bin / avr-g ++" -c -g -Os -w -std = gnu ++ 11 -fpermissive -fno-exceptions -ffunction-sections - fdata-sections -fno-threadsafe-statics -flto -w -x c ++ -E -CC -mmcu = atmega328p -DF_CPU = 16000000L -DARDUINO = 10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ cores \ arduino "" -IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ variants \ standard "" -IC: \ Users \ User \ Documents \ Arduino \ libraries \ Blynk \ src "" -IC: \ Users \ User \ Documents \ Arduino \ libraries \ BLEPeripheral-0.4.0 \ src "" C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_636113 \ sketch \ nRF8001.ino.cpp "-o "nul"
"C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr / bin / avr-g ++" -c -g -Os -w -std = gnu ++ 11 -fpermissive -fno-exceptions -ffunction-sections - fdata-sections -fno-threadsafe-statics -flto -w -x c ++ -E -CC -mmcu = atmega328p -DF_CPU = 16000000L -DARDUINO = 10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ cores \ arduino "" -IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ variants \ standard "" -IC: \ Users \ User \ Documents \ Arduino \ libraries \ Blynk \ src "" -IC: \ Users \ User \ Documents \ Arduino \ libraries \ BLEPeripheral-0.4.0 \ src "" C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_636113 \ sketch \ nRF8001.ino.cpp "-o "C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_636113 \ preproc \ ctags_target_for_gcc_minus_e.cpp"
C: \ Users \ User \ AppData \ Local \ Temp \ arduino_modified_sketch_866677 \ nRF8001.ino: 45: 23: fatal error: BLE
distans
January 11, 2018, 10:21pm
6
Did you try reinstall it?
yes on several occasions
He is also called to a friend to try it on his mac and he gives the same problem.
I use window 10
you could try? just compile arduino one?
Gunner
January 12, 2018, 9:07am
8
Why are you asking a Blynk forum to troubleshoot this Arduino BLEPeripheral library?
If you have an issue with it, report it on the GitHub site Issues · sandeepmistry/arduino-BLEPeripheral · GitHub
neurona
January 12, 2018, 11:46am
9
thanks for the answer Gunner.
e tried with their examples and if it works well it is with the example of blink with what does not work.
Gunner
January 12, 2018, 11:53am
10
Well, they are two different sketches and libraries… your OP error implied that you didn’t have all of the Libraries installed, or there was corrupted files, or pulling from the wrong library.
Aside from confirming that the hardware works and is connected correctly, there is no further use comparing the two different libraries and sketches.
Focus on confirming you have the latest Blynk library cleanly installed as well as the required “other” library… remove tham all and reinstall if necessary… and attempt to compile again.
neurona
January 12, 2018, 4:39pm
11
he used the V 5.0 library, which is the last one.
when I use the example of the v 5.0 library if it compiles but does not connect with blink server if with a bluetooh device.
with I use the example of the web
It does not work, it gives me the error.
