Arduino Uno Wifi Rev 2 connected for just seconds ... and then disconnects
Hi.
I’m encontering a very basic problem
I’ve an Arduino WiFi Rev 2.
First days (beginning April 2020) no problem with Blynk connection and basic testing. Everything fine. Great job, Blynk !
Now (two week later) I’m ready for a big project, but, surprise, the board remains connected for just few seconds, just the chance to switch on and off a led or move a servo and then is disconnected with no chance to reconnect again.
I’m powering with a 7,2V 2000mAh RC battery fully charged (7,9 volt metered).
Now I left only 2 leds, no servo, no other gadgets. No difference.
I used Vin as well as the external power socket. No difference.
I used home wifi as well as mobile tethering. No difference.
I used two different batteries. No difference.
I tried also the USB power adaper instead of battery pack. No difference.
It remain connected sometimes for 5 seconds, sometimes for 15 seconds. And stop
All Arduino driver library updated. App updated.
Even stranger that now I cannot anymore make the basic testing. I always get the same problem…
Ideas ?
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
#include <Servo.h>
char auth[] = "**************************";
char ssid[] = "Infostrada***********";
char pass[] = "*****************";
// char ssid[] = "*******************";
// char pass[] = "**************";
Servo servo;
BLYNK_WRITE(V3)
  servo.write(param.asInt());
  servo.attach(9);
This is the serial monitor report:
2:21:37.870 -> [3912] IP: 192.168.43.235
22:21:37.905 -> [3912]
22:21:37.905 ->     ___  __          __
22:21:37.939 ->    / _ )/ /_ _____  / /__
22:21:37.973 ->   / _  / / // / _ \/  '_/
22:21:38.006 ->  /____/_/\_, /_//_/_/\_\
22:21:38.006 ->         /___/ v0.6.1 on Arduino UNO WiFi Rev2
22:21:38.074 ->
22:21:38.074 -> [4041] Connecting to blynk-cloud.com:80
22:21:45.380 -> [11435] Ready (ping: 49ms).
22:22:05.495 -> [31548] Connecting to blynk-cloud.com:80
22:22:10.458 -> [36549] Connecting to blynk-cloud.com:80
22:22:15.471 -> [41550] Connecting to blynk-cloud.com:80
22:22:20.471 -> [46551] Connecting to blynk-cloud.com:80
22:22:25.461 -> [51552] Connecting to blynk-cloud.com:80
22:22:30.466 -> [56553] Connecting to blynk-cloud.com:80
22:22:35.437 -> [61554] Connecting to blynk-cloud.com:80
22:22:40.452 -> [66555] Connecting to blynk-cloud.com:80
Please note thata the complete functionality lasted only 20 seconds more or less.
This, while the board is registered as connected to the wifi access point.
Ideas ?
What exactly does this mean?
Hi.
It means that now the board loses the connection with blynk cloud even with the basic code:
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "+++++++++++";
char pass[] = "+++++++++";
Absolutely crazy behaviour.
It has no sense. I had to do more comparative test.
Else I can’t provide element to experts.
Thank you anyway
Have you tried rebooting your router?
Also, what happens when you turn on Blynk debugging?
Has there been any progress with this issue? I encountered the exact same problem. However when I commented the servo.attach() instruction the connection to blynk.cloud worked successfully and I was able to confirm that data was being passed from the Blynk app template to the device.
Alan
