Hi friends. I upload the below code from the blynk examples sketch to the arduino UNO with W5100 shield but after 5 second disconnected from the server !
the sketch:
#include <Ethernet.h>
char auth[] = "e5aac1087ca142ceaab95e9ad3198d6e";
char server[] = "10.5.51.5";
// Select your pin with physical button
const int btnPin = 11;
WidgetLED led3(V3);
// V3 LED Widget represents the physical button state
boolean btnState = false;
void buttonLedWidget()
// Read button
boolean isPressed = (digitalRead(btnPin) == LOW);
// If state has changed...
if (isPressed != btnState) {
if (isPressed) {
led3.on();
led3.off();
btnState = isPressed;
Blynk.begin(auth, server, 8080);
// Setup physical button pin (active low)
pinMode(btnPin, INPUT_PULLUP);
timer.setInterval(500L, buttonLedWidget);
the serial monitor log:
[0] Getting IP...
[5524] IP:10.5.51.9
[5524]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.4 on Arduino Uno
[5638] Connecting to 10.5.51.5:8080
[5688] Ready (ping: 9ms).
[10757] Connecting to 10.5.51.5:8080
[15758] Connecting to 10.5.51.5:8080
[20759] Connecting to 10.5.51.5:8080
