Arduino Uno/SIM900/2 relay/DHT22
Hello everyone!
I have a project with Uno, Sim900, 2 relays and dht 22 sensor.
Code from sketch builder.
#define TINY_GSM_MODEM_SIM900
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
#include <DHT.h>
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[]  = "YourAPN";
char user[] = "";
char pass[] = "";
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(7, 8); // RX, TX
TinyGsm modem(SerialAT);
#define DHTPIN 5          // What digital pin we're connected to
#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
  // Set GSM module baud rate
  SerialAT.begin(19200);
  delay(3000);
  modem.restart();
  dht.begin();
My issue is that after some time working, whole project freezes.
For example i started project, turned on relays, some time passed and arduino have no response for turning on/off relays and no data from dht.
Maybe there is any code to restart project any 15 min/ hour or other period.
You shouldn’t need to restart. Try finding the reason for the crash, possibly your cellular modem is dropping connection? Also, do you need to check the DHT22 every second? perhaps switch that to every 5-10 minutes.
modem was working well, it has external power supply, separated from arduino.
I will try to change data sending period.
I also have graph for dht, i have to change period of data to 1 day, because for 1 and 6 hours period data refreshes every minute, right?
No pinMode? I use 2 DHT22 sensors and have both set to INPUT_PULLUP in pinMode to simplify the circuit.
