Arduino Uno over usb on mac - "-bash: blynk-ser.sh: command not found"
Hi Guys, I’m trying to use the board on USB but getting an error when I try to execute the local server script. Not sure if i missed something ?
hi @sebastienb, do you follow the instructions here:
https://github.com/blynkkk/blynk-library/blob/master/examples/BoardsAndShields/Arduino_Serial_USB/Arduino_Serial_USB.ino
Have you installed Socat?
Thanks @Pavel I tried the instructions but did not install Socat. Going to try that now.
I’ve installed socat using macports but still get the same error when i try to run sudo ./blynk-ser.sh form the scripts folder.
Don’t run sudo ./blynk-ser.sh, only ./blynk-ser.sh
But for installing socat, you need to use sudo
just follow this to make sure your socat is install correctly: http://www.dest-unreach.org/socat/doc/README
Awesome thanks going to give it a try
Running without “sudo” giving me this error:
@Mykola do you have a better (bigger) screenshot of the error message?
